1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: epics gateway error message
To: wantianmin wantianmin <[email protected]>
Date: Sat, 2 Feb 2013 02:06:55 +0000
This might be caused by the page file being too small, and or because of a memory leak in the software. I don’t know of a leak, but we have to always consider the possibility. The memory leak situation can sometimes be identified when it is related to a linear increase in the virtual size of the Linux process correlated somehow to time or client initiated activity. The gateway does use free lists so its virtual size will remain at the high water mark of memory usage initiated by client load.
Jeff
From: wantianmin wantianmin [mailto:[email protected]]
Sent: Friday, February 01, 2013 6:08 AM
To: Hill, Jeff
Subject: epics gateway error message
hi,
   yestoday ,  When I check the epics gateway status,
 I found these error messages ,I am not sure about what happens.
I notice your messge (forward message to the email address)
So I paste these message and send to you.
by the way:
my epics gateway running on these environment:
OS: Linux (Centos,5.4,kernel:2.6.18-164.15.1.e15.centos.plusPAE)
EPICS:  base-3.14-11
gateway: 2_0_4_0
gcc,g++ version: gcc-4.1.2
I hope these information is helpful to you.
Error messages:
Jan 31 19:12:16 !!! Errlog message received (message is above)
timerQueue: Unexpected C++ exception "St9bad_alloc" with type "St9bad_alloc" during timer expiration callback
at Thu Jan 31 2013 19:12:26.313131210
Jan 31 19:12:26 !!! Errlog message received (message is above)
the _expression_ "this->numSubscriptions == 0" didnt evaluate to boolean true
and therefore internal problems are suspected at line 65 in "../../../../src/cas/generic/casEventSys.cc"
Please forward above text to [email protected] - thanks
numSubscriptions=1
filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=479
Memory allocation failed - unexpected problem with client's input - forcing disconnect
Jan 31 20:37:04 !!! Errlog message received (message is above)
at Thu Jan 31 2013 20:37:14.081768211
Jan 31 20:37:14 !!! Errlog message received (message is above)
numSubscriptions=1
Jan 31 20:37:24 !!! Errlog message received (message is above)
Jan 31 20:37:34 !!! Errlog message received (message is above)
Jan 31 20:37:46 !!! Errlog message received (message is above)
filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=605
Best Regards.
wantianmin
SSRF,Control Group
Prev: Re: Analog data acquisition in an EMI environment Pavel Maslov
Next: Re: Analog data acquisition in an EMI environment Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Job Openings at APS Nicholas Schwarz
Next: (epics-python) Cothread egg installation Emmanuel Mayssat
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
