1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with mca R7.2 and Rontec XFlash
To: Phillip Sorensen <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Wed, 06 Feb 2013 11:18:18 -0600
On 2/6/13 11:00 AM, Phillip Sorensen wrote:
> Hello,
> We are tring to setup the Rontec XFlash MCA with epics using the R7.2
> version of mca.
> The problem we are having is there seems to be a delay of some number of
> seconds after sending a command until we see an update in the MEDM
> screen.  For example clicking the start and stop buttons for the
> acquisition show this.  I we look at the XFlash unit it seems to update
> the front panel immediately, but the MEDM screen shows a delay.  The
> spectrum update (which is set to 1 second) also seems to take 5 to 10
> seconds per update.
> We are not getting any timeout errors.  Any suggestions?
Hi, Phil.
Over what physical link are you communicating with the XFlash?  If it's
RS-232, it could just take that long to transmit the data over the slow
link.
Lewis
Problem with mca R7.2 and Rontec XFlash Phillip Sorensen
Prev: Problem with mca R7.2 and Rontec XFlash Phillip Sorensen
Next: Does anyone have an Ethernet based scaler ? Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Problem with mca R7.2 and Rontec XFlash Zachary Brown
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
