1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: header files in snc code
To: Tech Talk <[email protected]>
Date: Fri, 8 Feb 2013 12:04:27 -0600
I'm building a state machine in which I will have ~100 variables which I will monitor
and to which I will write.  I would like to make my source code more clear by putting
this list in a header file.  I could not find anything in the documentation other than
including a c-style header file with the appropriate "%%".  Can I add a header file
in which I make all of the assignments and monitors?
Thank you,
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Re: header files in snc code Tim Mooney
Prev: Re: Problem with mca R7.2 and Rontec XFlash Zachary Brown
Next: Re: header files in snc code Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: support module for Xspress 3 matthew.pearson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
