Subject: |
AsynInt32 device support and mbbo records |
"Florian Feldbauer" <[email protected]> |
To: |
"EPICS Tech Talk" <[email protected]> |
Date: |
15 Feb 2013 10:14:38 +0100 |
Hey,
I have written an AsynPortDriver for the TMCM142 1 axis stepper
driver/controller
The motor driver is connected via CAN bus and expects a message with 7
bytes of data:
byte 0: command number
byte 1: parameter number (I'm using the addr parameter from the asyn
interface)
byte 2: motor number (only one motor can be connected to the driver so
it is always 0)
byte 3-6: data (32 bit signed int)
For setting the microstep resolution of the motor driver the data has to
be a number between
0 and 11, each coding a different resoultion.
I wanted to use a mbbo record, which looks like this:
record( mbbo, "PANDA:$(subsys):MOTOR:$(SECTOR):SAP:USTEPRESOLUTION" ) {
field( DTYP, "asynUInt32" )
field( OUT, "@asyn($(BUS),27,1)TMCM142_SAP" )
field( ZRST, "2048 micro steps" )
field( ONST, "1024 micro steps" )
field( TWST, "512 micro steps" )
field( THST, "256 micro steps" )
field( FRST, "128 micro steps" )
field( FVST, "64 micro steps" )
field( SXST, "32 micro steps" )
field( SVST, "16 micro steps" )
field( EIST, "8 micro steps" )
field( NIST, "4 micro steps" )
field( TEST, "2 micro steps" )
field( ELST, "1 micro steps" )
Unfortunately, the value inside my writeInt32 function from the
asynPortDriver is always 0.
Do I have to set the ZRVL,...,ELVL fields for asynInt32? Or do I need
another asyn interface for
this record?
Best regards,
Florian
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 45 |
| D-55128 Mainz |
| Office: 01/217 |
| Phone: (+49)6131 / 39-25829 |
- Re: AsynInt32 device support and mbbo records Burkhard Kolb
- RE: AsynInt32 device support and mbbo records Mark Rivers
record info field in which epics version? Emmanuel Mayssat
<2013>
2025
Re: record info field in which epics version? Andrew Johnson
<2013>
2025
