1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: aSub MAX_ARRAY_SIZE increase
To: <[email protected]>
Date: Sun, 17 Feb 2013 06:13:08 +0000
Hi tech-talk,
I have an EPICS application that runs on Linux/Darwin where I need to increase the value of MAX_ARRAY_SIZE in aSubRecord.c from ten million to 200 million or possibly even 1000 million. Apart from creating a version of EPICS that is only locally compatible (and needing lots of memory to run) are there any likely problems with this change?
cheers,
Euan.
Euan Troup CSIRO Astronomy & Space Science    +61 2 9372 4660
[email protected]<mailto:[email protected]>
RE: aSub MAX_ARRAY_SIZE increase Hu, Yong
Re: aSub MAX_ARRAY_SIZE increase Andrew Johnson
Prev: Re: record info field in which epics version? Andrew Johnson
Next: RE: aSub MAX_ARRAY_SIZE increase Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Has anyone converted AllenBradley (scanner) driver and device support to EPICS OSI? Luchini, Kristi L.
