1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway: strange configuration
To: [email protected]
Date: Thu, 21 Feb 2013 05:42:32 -0600
Hi Pierrick,
I would think that on the gateway you should have your sip = 111.11.11.11
and you cip = broadcast IP of your 222.22.22.22 network or perhaps just the
222.22.22.22 IP address itself. It is likely I would think that you do not
have a static public IP address so it is possible that sometime in the future
your IP address may get changed once the lease expires.
I think that your EPICS_CA_ADDR_LIST on your remote machine will likely be
the 222.22.22.22 IP. Then if you at least attempt to connect to a PV from
the gateway ... I usually use camonitor or some other tool that will keep
trying to connect. There should be a flag for getting a gateway report which
should be of the form $(GW_PRFIX):report1Flag which should generate a virtual
connection report and put it in gateway.report file located where you started
the gateway from.
From this file you should be able to see any connections to PVs on the gateway.
This should show you the PV name as well as who is connected to it and from
where.
Hope that this helps out.
Marty
On 02/20/13 15:33, Pierrick Hanlet wrote:
Hi Ralph,
Thanks for the response. I suppose that I'm being a bit thick, but I'm not able
to understand
your instructions. In starting the gateway, I added the flag "-debug 50". I
cannot connect
from my remote machine 333.33.33.33; I've attempted caget with hopes that the
log file
on the gateway machine will show some attempt to connect, but to no avail. If
this is not
what you mean, would you please be more specific?
Pierrick
On 02/20/2013 11:27 AM, Ralph Lange wrote:
On 20.02.2013 18:09, Pierrick Hanlet wrote:
Hi all,
I'm running an epics gateway v2.0.4 on a linux box running SL with kernel
2.6.18 and is part of a LAN;
my EPICS version is 3.14.11. We have established an external connection to
this subnet with a DSL
connection with a public IP address and an ethernet cable from the DSL modem.
I have no name for
this public IP address.
So, my questions are:
1) How do I set up my gateway.access file?
2) On my remote node, how do I define my EPICS_CA_ADDR_LIST?
3) Can I even use an IP address in the access file?
Let's say that my host computer running the gateway is 111.11.11.11, the
public IP address is 222.22.22.22,
and my remote machine on which I want the EPICS data is 333.33.33.33.
I've tried a variety of things and I'm clearly missing something. On my other
uses of the gateway, I don't
have the intermediate hop over the AT&T provided public IP address.
Pierrick
Hi Pierrick,
I would say for the remote client
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_NAME_SERVERS= 222.22.22.22
On the gateway, I would turn up debugging, connect from the remote client, and
check what it provides as user and host. These will be the values to use in
the Access Security configuration.
Good luck!
~Ralph
"Whether you think you can or think you can't, either way, you are correct" --
Henry Ford
_______________________________________________________________
*Pierrick Hanlet*
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
gateway: strange configuration Pierrick Hanlet
Re: gateway: strange configuration Ralph Lange
Re: gateway: strange configuration Pierrick Hanlet
Prev: asyn R4-21 available Mark Rivers
Next: Re: gateway: strange configuration Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gateway: strange configuration Pierrick Hanlet
