1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Rounding in conversion of ao record
To: haquin <[email protected]>, tech-talk <[email protected]>
Date: Thu, 21 Feb 2013 13:52:19 +0000
Conversion to epicsInt32 is not normally part of the operation of the ao record.  What device support are you using?
From: [email protected] [[email protected]] on behalf of haquin [[email protected]]
Sent: Thursday, February 21, 2013 7:12 AM
To: tech-talk
Subject: Rounding in conversion of ao record
Hi people,
There is a rounding operation (cast to (epicsInt32)) when using the conversion of the ao record,
hence, with this conversion only integer is output, no float ...
This is surprising and not equivalent to what is done for the ai record.
Could this be changed ?
Christophe
Re: Rounding in conversion of ao record haquin
Prev: Rounding in conversion of ao record haquin
Next: Re: Rounding in conversion of ao record haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
