1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572
To: <[email protected]>
Date: Sat, 23 Feb 2013 18:22:40 +0800
Hello,
When I load an EPICS example application to the vxWorks5.5.1 running on a MPC8572 CPU board, "Undefined symbol" is reported as follows,
ld <bin/vxWorks-mpc8572/example.munch
Undefined symbol: clone__Q2t12basic_string3ZcZt18string_char_traits1ZcZt24__default_alloc_t)Undefined symbol: __tf9exception (binding 1 type 0)
Undefined symbol: _vt$9bad_alloc (binding 1 type 0)
Undefined symbol: __cp_push_exception (binding 1 type 0)
Undefined symbol: __tf9bad_alloc (binding 1 type 0)
Undefined symbol: unexpected__Fv (binding 1 type 0)
Undefined symbol: __uncatch_exception (binding 1 type 0)
Undefined symbol: __tfv (binding 1 type 0)
Undefined symbol: _t24__default_alloc_template2b1i0$_S_free_list (binding 1 type 0)
Undefined symbol: __rtti_user (binding 1 type 0)
Undefined symbol: __rtti_si (binding 1 type 0)
Undefined symbol: _$_9bad_alloc (binding 1 type 0)
Undefined symbol: __check_eh_spec (binding 1 type 0)
Undefined symbol: __get_eh_context (binding 1 type 0)
Undefined symbol: __sjthrow (binding 1 type 0)
Undefined symbol: replace__t12basic_string3ZcZt18string_char_traits1ZcZt24__default_alloc_t)Undefined symbol: terminate__Fv (binding 1 type 0)
Undefined symbol: _t12basic_string3ZcZt18string_char_traits1ZcZt24__default_alloc_template2)Undefined symbol: _vt$13runtime_error (binding 1 type 0)
Undefined symbol: __start_cp_handler (binding 1 type 0)
Undefined symbol: _t24__default_alloc_template2b1i0$_S_node_allocator_lock (binding 1 type )Undefined symbol: __cp_pop_exception (binding 1 type 0)
Undefined symbol: __ti9exception (binding 1 type 0)
Undefined symbol: _vt$9exception (binding 1 type 0)
Undefined symbol: __builtin_vec_new (binding 1 type 0)
Undefined symbol: __eh_rtime_match (binding 1 type 0)
Undefined symbol: __builtin_vec_delete (binding 1 type 0)
Undefined symbol: __rtti_class (binding 1 type 0)
Undefined symbol: __builtin_delete (binding 1 type 0)
Undefined symbol: __terminate (binding 1 type 0)
Undefined symbol: __builtin_new (binding 1 type 0)
Undefined symbol: _vt$11logic_error (binding 1 type 0)
Undefined symbol: __eh_alloc (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
Checking the vxWorks image, it indeed does not include these symbols. And use "grep -r" to check the gnu library on the vxWorks host, the library files libcplus.a and libgnucplus.a under Tornado2.2/target/lib/ppc/PPC403/gnu, PPC405/gnu, PPC440/gnu, PPC603/gnu, PPC604/gnu and PPC860/gnu do provide these symbols, but the libcplus.a and libgnucplus.a under Tornado2.2/target/lib/ppc/PPC85XX/gnu directory do not provide, which seems to cause the above error.
Do you have encountered such a problem before?
Lin Wang
Re: Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572 Dirk Zimoch
Prev: Re: EPICS Modbus module + PLC Pavel Maslov
Next: Re: Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Race condition during IOC startup? Andrew Johnson
