1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Question about epid record
To: Bruce Hill <[email protected]>
Date: Wed, 27 Feb 2013 13:56:29 +0000
Hi Bruce,
Thinking about this a little more I think there are advantages of the EPID formulation versus the classical one in terms of scale-independence of the KI and KD terms.
There are input units for the error (let's use degrees for example) and output units for the control variable (let's use volts for example).
The dimensions of the KP, KI and KD terms in the classical formulation are:
KP = volts/deg
KI = volts/deg/sec
KD = volts*sec/deg
In the EPID formation the units are:
KP = volts/deg
KI = 1/sec = Hz
KD = sec
So KI and KD are independent of the input and output units, they are in pure units of Hz and time.  This means that if, for example, I change the input units from degrees C to degrees F, or the output units from volts to millivolts I don't need to change KI or KD, I only need to change KP.
Sent: Wednesday, February 27, 2013 12:36 AM
To: Mark Rivers
Cc: [email protected]
Subject: Question about epid record
Hi Mark,
I'm in the process of replacing a genSub based PID controller with
the epid record that you and Bob developed, and I'm puzzled by a difference
in how the two compute the I and D terms.
In the classical PID algorithm, the value of M(n), the manipulated variable is
M(n) = KP*(E(n) + KI*SUMi(E(i)*dT(i)) + KD*(E(n) -E(n-1))/dT(n)
In fact, the above is from line 33 of devEpidSoft.c, and agrees with
other descriptions I've found of the PID calculation.
However, in the do_pid() function, and in epidRecord.html, the
calculation includes the KP gain in the integral and derivative terms.
M(n) = KP*(E(n) + KP*KI*SUMi(E(i)*dT(i)) + KP*KD*(E(n) -E(n-1))/dT(n)
I can scale my KI and KD gain factors by KP to get the equivalent result,
but I don't see why the effective integral gain should be affected when
the proportional gain is tweaked.  Ditto for KD.
Any comments or clarification would be appreciated.
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Laboratory
Re: Question about epid record Bruce Hill
Prev: Installing EPICS&MEDM on UBUNTU Yasemin Barutçu
Next: AW: Question about epid record Pal Trivan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: AW: Question about epid record Pal Trivan
Next: Re: Question about epid record Bruce Hill
