1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building an Epics module only for a target (not host)
Cc: [email protected]
Date: Thu, 28 Feb 2013 12:09:27 -0500
On 02/28/2013 12:04 PM, Andrew Johnson wrote:
Hi Michael,
On 2013-02-28 Michael Davidsaver wrote:
In addition to the  'PROD' variable you can also use 'PROD_$(OS_CLASS)'
and 'PROD_$(ARCH)').  For example:
PROD_RTEMS = rtemsSpecificIoc
PROD_linux-x86 = reallySpecificIoc
Beware of the second form, it is very specific.  This example will not
build for the debug target 'linux-x86-debug'.
Are you sure the second form actually exists in the rules?
I was mis-remembering.  The actual use was:
ifeq ($(T_A), linux-x86)
PROD += ...
endif
Building an Epics module only for a target (not host) Florian Feldbauer
Re: Building an Epics module only for a target (not host) Michael Davidsaver
Re: Building an Epics module only for a target (not host) Andrew Johnson
Prev: Re: Building an Epics module only for a target (not host) Andrew Johnson
Next: Strange Interaction between CA gateway and CAJ Carr, Gary
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: JCA Error Lucas José
