1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector R1-9 released
To: "'[email protected]'" <[email protected]>
Cc: "[email protected]" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 1 Mar 2013 16:42:28 +0000
Hi Richard,
Thanks for finding that problem.
R1-9 does not work with detectors that use TCP socket servers (Pilatus, marCCD, mar345, PSL, and Bruker) because drvAsynIPPort.dbd was not being included in the build.
The R1-9-1 release notes contain a link to a patch for R1-9:
http://cars9.uchicago.edu/software/epics/areaDetectorReleaseNotes.html
R1-9-1 does not exist yet.  I will release it next week, after seeing if any other problems are found.
-----Original Message-----
Sent: Friday, March 01, 2013 8:13 AM
To: Mark Rivers
Hi Mark,
I'm having a problem running (not building) the Pilatus driver.
I noticed this commit in the areaDetector repository:
r15685 | rivers | 2012-12-13 19:31:44 +0000 (Thu, 13 Dec 2012) | 1 line
Changed paths:
   D /areaDetector/trunk/ADApp/pilatusSrc/pilatusDetectorAppInclude.dbd
Now built dynamically
Trouble is, I'm not sure that file is built dynamically :-|
All I do with the source code is:
* Modify configure/RELEASE as appropriate
* make
* Set the camserver hostname in iocBoot/iocPilatus/st.cmd to "localhost" (for testing)
* Run pilatusDetectorApp with st.cmd
The results with different versions are:
* 1-8 - builds fine, runs fine, connects to (fake) camserver.
* 1-9 - builds fine, but when run, reports the error "st.cmd -- Line 16 -- Command drvAsynIPPortConfigure not found."
* 1-9, with pilatusDetectorAppInclude.dbd from 1-8 - builds and runs fine.
Am I missing a step, or is there really a problem with pilatusDetectorAppInclude.dbd no longer being included?
Richard
Richard Fearn
Senior Software Engineer
Diamond Light Source Ltd.
Tel: +44 1235 778655
areaDetector R1-9 released Mark Rivers
Prev: RE: Crystal Logic goniometer Myers, Stuart F
Next: Re: What I learned today... Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: areaDetector R1-9 released Mark Rivers
Next: Micronix motor controller Fairley, Diane M.
