1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: database runtime acess
To: [email protected]
Date: Wed, 6 Mar 2013 00:40:09 -0600 (CST)
Device support has priviledged access to a record's fields, and should not use channel access to change a field value.  (dbPutField uses channel access.)  Just write directly to the field (for example, "prec->val = 3;").  Make sure you then call db_post_events() so everybody else will know that you've changed the field value.
Tim
----- Original Message -----
> From: [email protected]
> To: "tech-talk" <[email protected]>
> Sent: Tuesday, March 5, 2013 11:19:23 PM
> Subject: database runtime acess
> hello:
> I want to change a process valiable's field at runtime in the device
> support. The record type is writen by myself.
> I do it using the dbPutField() as the 15th chapter of application
> developer's guide said.
> but I always get an segment fault after i process the record's field
> at runtime.
> Am I do it somewhere wrong?
database runtime acess ahwwq
Prev: database runtime acess ahwwq
Next: RE: EPICS Record Support luedeke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: MEDM won't compile in Cygwin: "Too many open files" Poff, Mark A
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
