I would like to create a panel to be used with IO device with many channels. I am now wondering if there is a way how to set PV to widgets like parameters (e.g. to set PVs to $device:DIO:$port_$channel and then set those parameters/variables
in some startup scrip or Java code common for the whole panel? Or is there other recommanded way how to do that?
I am also wandering if there is a way how to trigger a script associated with the widget by an action not related to the PV (e.g. I would like to change color of a widget if a button is pressed)?
I have just started with BOY so my question is probably stupid, but I was not able to find a solution in a documentation I have read so far….
Thanks in advance for help!
Cheers,
Mike
