See "Channel Access Host Example" (section 2.3) in the Application Developer's Guide.
Here's a link:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node3.html#SECTION00330000000000000000
Running the command will make you an example ca client that accesses a record's field (also called a "pv").
The string you specify to refer to a record's field ("myRecord.VAL", for example) is called a "pvname".
Tim
----- Original Message -----
> From: [email protected]
> To: "tech-talk" <[email protected]>
> Sent: Thursday, March 7, 2013 9:32:03 PM
> Subject: Channel Access
> Hi,
> Does anybody know how to acess to a record's field using channel
> access in the client.
- Channel Access ahwwq
Labview as Server and Probe as client, connection problem. Emir Drossa
<2013>
<2013>
