1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM Text Control Widget Motif behavior
To: "Sinclair, John William" <[email protected]>
Date: Sun, 10 Mar 2013 18:59:48 -0800
Hi John,
I tried adding an XmNalignment parameter to the calls to
XtVaCreateManagedWidget()  in baselib/x_text_dsp_obj.cc,
but it didn't help.   I did some Xt/Xm gui work back in the 90's,
and as I recall that should have worked if the widget supported it.
If you have some other ideas on how to fix this that would be great,
but family takes precedence.   This is just a cosmetic issue.
Best wishes to you and yours,
- Bruce
On 3/9/2013 6:53 PM, Sinclair, John William wrote:
Bruce,
I don’t thinks that’s true. Let me look a bit and see if I can fix this.
I have some pressing family issues at the moment so progress might be delayed.
Best,
John Sinclair
From: [email protected] [mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Friday, March 08, 2013 9:37 PM
To: Isadoro Carlino
Cc: [email protected]
Hi Terry,
I've been bothered by the same lack of alignment in
our edm text controls.   Your email got me thinking about
it and I looked into it more.    It appears the root problem
is that the motif XmTextField widget that this edm widget
is based on does not support alignment!
See Looking for TextField with right-align
There are some commercial solutions
Oracle Complex Text Layout Extensions to Motif
ICS Motif EnhancementPak
but I haven't found any open src solution yet.
- Bruce
On 02/20/2013 12:28 PM, Isadoro Carlino wrote:
Noted a "feature" of the EDM Text Control Widget. If motif is selected the Font justification control has no effect. The text will always be at the top left corner of the widget input field. This makes some kinds of widget positioning, especially using code generated screens difficult. We're using edm version 1-11-1zm with Text Control major 4 minor 1 version.
Does anyone know if this has been fixed in later version of EDM or is it a function of using motif? The widget font justification works as expected if motif isn't selected, unfortunately you are then left with a separate dialog box opening for input. I also know that the Textentry Widget allows direct entry without motif, but it does not allow units to be surpressed and lacks many of the other features of Text Control.
Any help would be appreciated, before I try to tear into the widget code myself to see if I can fix the problem.
Terry Carlino
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
EDM Text Control Widget Motif behavior Isadoro Carlino
Re: EDM Text Control Widget Motif behavior Bruce Hill
RE: EDM Text Control Widget Motif behavior Sinclair, John William
Prev: RE: Area Detector Mark Rivers
Next: Re: Area Detector Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EDM Text Control Widget Motif behavior Sinclair, John William
Next: Re: EDM Text Control Widget Motif behavior Isadoro Carlino
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
