1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: gethostbyname and getaddrinfo - multiple DNS entries for a hostname
To: "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>
Cc: Eric Norum <[email protected]>
Date: Mon, 11 Mar 2013 16:56:56 +0000
> The osi/os/WIN32/osdSock.c file could easily be changed to use getaddrinfo()
> instead of gethostbyaddr() and getnameinfo() instead of gethostbyname().  Do
> you know when Microsoft introduced the newer routines?  Would making this
< change prevent EPICS from running on some older versions of Windows?
According to this document the minimum Windows version is Windows 2000, which I believe means that it won't run on Windows NT, but it will run on XP, Vista, Windows 7 and Windows 8.
http://msdn.microsoft.com/en-us/library/windows/desktop/ms738520(v=vs.85).aspx
I doubt if anyone is running EPICS on NT?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, March 11, 2013 11:45 AM
To: [email protected]
Cc: Eric Norum
Subject: Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname
On 2013-03-11 Eric Norum wrote:
> Right -- we'd have to copy the existing posix/osdSock.c from posix/ to
> RTEMS/ before making the getaddrinfo change to posix/osdSock.c.
This is starting to sound more like a 3.15-level change now, since it's going
to affect multiple architectures.  I confirmed Michael's observation that
getaddrinfo() is not provided in RTEMS 4.9.2.
On 2013-03-11 Mark Rivers wrote:
> I checked an getaddrinfo also appears to be present on Windows.  If this
>  adds useful functionality then should it also be changed in the Windows
>  OSI code?
I suspect that unless you're suffering the same issues that Matt reported this
wouldn't really make any difference.  I don't think it really adds any
functionality other than apparently checking local host names before or as
well as the DNS, although on Linux the older APIs are now documented as being
obsolete.
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
gethostbyname and getaddrinfo - multiple DNS entries for a hostname matthew.pearson
Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Michael Davidsaver
Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Eric Norum
Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Andrew Johnson
Prev: Re: epics-perl & perlapi-5.10.1 Martin Konrad
Next: Re: Save and Restore parameters Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Eric Norum
Next: Re: gethostbyname and getaddrinfo - multiple DNS entries for a hostname Andrew Johnson
