1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Example app won't run on cygwin
Date: Wed, 13 Mar 2013 10:57:24 -0400
That works, though I do get a number of errors when the IOC is running:
../online_notify.c: CA beacon routing (connect to
"169.254.255.255:5065") error was "Network is unreachable"
That may just be due to the internet connection here rather than any
problems with st.cm.
James
On Wed, Mar 13, 2013 at 10:51 AM, Mark Rivers <[email protected]> wrote:
> What happens if you run it manually by typing from the iocboot/iocexample directory:
> ../../bin/cygwin-x86/example st.cmd
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of James F Ross
> Sent: Wednesday, March 13, 2013 9:48 AM
> To: EPICS Tech Talk
> Subject: Example app won't run on cygwin
> Hello all,
> I've just managed to build epics base 3.14.11 on cygwin and I compiled
> the example app, but when I try to run the st.cmd file there are some
> odd errors that I've never encountered before.  Has anyone run into
> these before?
> Once the example app is built, here is a complete list of what I did:
> $> cd /home/jfross/epics/exampleApp/iocBoot/iocexample
> $> chmod +x st.cmd
> $> ./st.cmd
> C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>#!../../bin/cygwin-x86/example
> '#!..' is not recognized as an internal or external command,
> operable program or batch file.
> C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>## You may
> have to change example to something else
> '##' is not recognized as an internal or external command,
> everywhere it appears in this file
> The syntax of the command is incorrect.
> C:\cygwin\home\jfross\epics\exampleApp\iocBoot\iocexample>< envPaths
RE: Example app won't run on cygwin Mark Rivers
Example app won't run on cygwin James F Ross
Prev: RE: Example app won't run on cygwin Mark Rivers
Next: RE: Example app won't run on cygwin Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
