1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SNMP device support
To: EPICS Tech Talk <[email protected]>
Date: Tue, 19 Mar 2013 08:31:01 -0500
Florian,
We're using an MPod crate with iSeg HV supplies.  I started with the DESY version and I did manage to get that to work.  But found John Priller's code to be much easier to work with.
Paul
On Mar 19, 2013, at 5:57 AM, Marty Smith <[email protected]> wrote:
> Hi Florian,
> I have been testing an application using the driver from Sheng Peng since
> it does provide write capabilities via SNMP. However, I have noticed that
> during my testing the on a Linux-x86 64-bit machine running under EPICS
> R3.14.12.2 that the soft IOC does use more and more memory over time indicating
> a possible memory leak. However, I have not confirmed the source of the problem
> at this time. I am trying to find some time to test the one from John Priller
> but as of yet have not been able to.
> My application is providing data from rack mounted APC power strips. In the
> next few weeks I intend on finding some time to set up a test using John's
> driver though which Eric Norume has provided updates for.
> https://groups.nscl.msu.edu/controls/files/snmp-nscl-1.0.RC6.tgz
> Marty Smith
> ANL/APS Controls Group
> From: "Florian Feldbauer" <[email protected]>
> To: "EPICS Tech Talk" <[email protected]>
> Sent: Tuesday, March 19, 2013 5:19:12 AM
> Subject: SNMP device support
> Dear all,
> for our low voltage power supply, we are thinking about using the Wiener
> MPod which is controlled via SNMP.
> From Wiener I know that there are some implementations for EPICS:
> - The original devSNMP from DESY
> http://www-mks2.desy.de/content/e4/e40/e41/e12212/index_ger.html
> - An extension of the first one from John Priller
> http://groups.nscl.msu.edu/controls/
> - and a third one from Sheng Peng from Diamond light source
> http://controls.diamond.ac.uk/downloads/misc/snmp.tgz
> Is there any great difference in those device supports? Especially
> between the second and third one?
> Are there any recommendation which one to use?
> Best regards,
> Florian
> | Dr. Florian Feldbauer                |
> | Helmholtz-Institut Mainz /           |
> | Johannes Gutenberg-Universität Mainz |
> | Johann-Joachim-Becher-Weg 45         |
> | D-55128 Mainz                        |
> | Office: 01/217                       |
> | Phone:  (+49)6131 / 39-25829         |
Re: SNMP device support Marty Smith
Prev: Re: SNMP device support Marty Smith
Next: RE: SNMP device support nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
