1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Building caQtDM on Ubuntu Linux 12.04
To: [email protected]
Date: Mon, 01 Apr 2013 13:31:32 -0700
Hello,
I'm unable to build caQtDM for Ubuntu using the 2.8.0 sources.
The following output is generated by running the caQtDM_Build script:
=========== remove binaries from directory =============
========== remove makefiles from directories ============
=========== clean all ==================
Cannot find file: all.pro.
make: *** No rule to make target `distclean'.  Stop.
============ make all =================
./caQtDM_Build: line 28: dye: command not found
=========== build plugins =============
./caQtDM_Build: line 32: linuxbuild: command not found
=========== do not forget to copy plugins /Qt-4.8.2/plugins/designer/
Is the file "all.pro" missing from the 2.8.0 sources?
Where does the "dye" command come from?
Thanks!
Jason
Prev: RE: SIS3820 scaler limits Mark Rivers
Next: EPICS Qt Framework SVN repository Ricardo Fernandes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: EPICS device driver support for Tektronix AFG3000C Tang, Johnny Y.
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
