Can you send the database you are using that invokes that protocol file?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Alan Greer
Sent: Monday, April 08, 2013 9:17 AM
To: [email protected]
Subject: Stream Device and Asyn
Hi all,
I have an Asyn driver (SSH) that I'm attempting to use with Stream Device.
My setup
EPICS_BASE=/home/epics/R3.14.12.2/base
ASYN=/home/epics/R3.14.12.2/asyn4-18
STREAM=/home/epics/R3.14.12.2/stream2-6
Here is my protocol file
>> more test.proto
stringIO {
out "cpu\n";
When I process the record that executes the stringIO routine I get the
following IOC output (with asyn trace set)
epics> 2013/04/08 15:03:39.859 SSH1 addr -1 queueRequest priority 0 not
lockHolder
2013/04/08 15:03:39.859 SSH1 schedule queueRequest timeout
2013/04/08 15:03:39.859 asynManager::portThread port=SSH1 callback
2013/04/08 15:03:39.859 SSH1 addr -1 queueRequest priority 0 not lockHolder
2013/04/08 15:03:39.859 device read.
2013/04/08 15:03:39.859 Close device connection (fd -1221589168): Read error
2013/04/08 15:03:39.859 Open connection to device reason:0
2013/04/08 15:03:40.346 Opened connection to device
2013/04/08 15:03:40.347 Close device connection (fd -1221589168): Read error
2013/04/08 15:03:40.347 device read.
When I look at those messages I agree that the device read will return a
read error, as there is nothing to read back. What I don't understand
is why readIt is called at all. I was expecting the protocol function
to only call into writeIt. What I see is that readIt appears to be
called with a timeout of 0. Can anyone help me with this? My asyn
driver is (loosely) based on the drvAsynIPPort driver, with an
additional library in place of the actual socket calls made, and
simplified as much as possible.
The output messages continue indefinitely when I process the record,
disconnecting, reconnecting, attempt a read... etc.
I have successfully used the driver with a custom asyn motor record
device support layer, and so the driver is functional (at least to some
extent!)
Any help or suggestions would be appreciated.
Kind regards, Alan Greer
- Re: Stream Device and Asyn Alan Greer
- Stream Device and Asyn Alan Greer
<2013>
<2013>
