For some reason you're missing org.csstudio.archive.rdb in your product.
You have it in the workspace, but it's not in the product.
Check your run configuration: From the menu “Run”, “Run Configurations...”. Locate the Eclipse Application entry for your product, select the “Plug-ins” tab and press the “Validate Plug-Ins” button.
See http://cs-studio.sourceforge.net/docbook/ch15.html
Maybe org.csstudio.archive.rdb is simply not selected, or it's missing a dependency.
-Kay
On Apr 12, 2013, at 12:02 , James F Ross wrote:
Hello all,
I'm having trouble with eclipse in trying to get the rdb archiver set up. I've managed to track down all the plug-ins I need (I think), but for some reason when I go to ArchiveEngine.product and click "Launch an Eclipse Application" I get a number of errors regarding org.csstudio.archive.rdb_3.0.1.
I have this version of org.csstudio.archive.rdb included in the workspace. Any idea why the product file might not see/recognize it? I've included my full error log file below. I am running eclipse 3.7.2 and java 1.6.0_37 on 64 bit Scientific Linux 5.8.
Thanks all,
James Ross
error log:
!SESSION 2013-04-12 11:43:11.931 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_37
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.csstudio.archive.engine.engine
Command-line arguments: -product org.csstudio.archive.engine.engine -data /home/sysuser/CSS/cssTest/css-nsls2/workspace/../runtime-ArchiveEngine.product -dev file:/home/sysuser/CSS/cssTest/css-nsls2/workspace/.metadata/.plugins/org.eclipse.pde.core/ArchiveEngine.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2013-04-12 11:43:12.510
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-04-12 11:43:12.510
!MESSAGE Bundle initial@reference:file:../../../home/sysuser/CSS/cssTest/css-nsls2/plugins/org.csstudio.archive.config.rdb/ was not resolved.
!SUBENTRY 2 org.csstudio.archive.config.rdb 2 0 2013-04-12 11:43:12.510
!MESSAGE Missing required bundle org.csstudio.archive.rdb_3.0.1.
!MESSAGE Bundle initial@reference:file:../../../home/sysuser/CSS/cssTest/css-nsls2/plugins/org.csstudio.archive.writer.rdb/ was not resolved.
!SUBENTRY 2 org.csstudio.archive.writer.rdb 2 0 2013-04-12 11:43:12.511
!ENTRY org.eclipse.osgi 2 0 2013-04-12 11:43:12.512
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-04-12 11:43:12.512
!MESSAGE Bundle org.csstudio.archive.config.rdb_1.0.0.qualifier [24] was not resolved.
!SUBENTRY 2 org.csstudio.archive.config.rdb 2 0 2013-04-12 11:43:12.512
!MESSAGE Bundle org.csstudio.archive.writer.rdb_1.0.0.qualifier [28] was not resolved.
!SUBENTRY 2 org.csstudio.archive.writer.rdb 2 0 2013-04-12 11:43:12.512
!ENTRY org.eclipse.osgi 4 0 2013-04-12 11:43:12.513
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ant.core.antRunner" could not be found in the registry. The applications available are: org.csstudio.archive.engine.application, org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
- Re: rdb archiver and eclipse help James F Ross
- rdb archiver and eclipse help James F Ross
<2013>
<2013>
