Subject: |
RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam |
Emmanuel Mayssat <[email protected]> |
To: |
Eric Norum <[email protected]> |
Date: |
Thu, 18 Apr 2013 12:20:43 -0700 |
What happen when placed after the iocInit? It works!!!
Indeed, the asynSetTraceMask call was just before (no dbLoadXXX in between). Now, it is just after. The behavior is different. The -1 asynAddress is now behaving as expected.
Thanks, -- E
Subject: Re: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam From: [email protected]Date: Thu, 18 Apr 2013 09:41:19 -0700 CC: [email protected]To: [email protected]Note that asynSetTraceMask "myPort",-1,0x9 will have an effect only on addresses that are registered at the time that the asynSetTraceMask is invoked.
Addresses which are registered later as the result of things like dbLoadRecords will not have their trace mask set. What happens if you move the asynSetTraceMask to after the iocInit? > From: [email protected]> If you want to print ASYN_TRACE_ERROR and ASYN_TRACEIO_DRIVER messages for a records with ANY asyn address then you do > asynSetTraceMask "myPort",-1,0x9 > Is this what you are asking?
Yes, except that the -1 asynAddress is what I had initially... and that doesn't work for ANY address (but for address 0).
But setting the asynTrace flags for each asynAddress works as expected.
PS: asyn 4-12 + epics-base 3.14.11 + fedora 8 IOC PS: I am using ASYN_MULTIDEVICE as previously recommended
FYI
-- Emmanuel
- asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
- RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Mark Rivers
- RE: asynAddress, asynPortDriver maxAddr, and addr in setXXXParam Emmanuel Mayssat
Re: Linux USB serial questions J. Lewis Muir
Re: Linux USB serial questions Dale L. Brewe
<2013>
CA beacon / ENOBUFS Benjamin Franksen
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
