1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Add choice to dbd file
Cc: [email protected]
Date: Fri, 19 Apr 2013 16:59:40 +0100
Thanks Andrew,
It's working! :)
2013/4/19 Andrew Johnson <[email protected]>
Hi Bruno,
On 2013-04-19 Bruno Santos wrote:
> Anybody know how I can put this line "choice(menuScan60_second,"60
> second")" permanently on the dbd file generated after compilation? Note
> that I can put this manually but if I recompile the line is not kept...
Copy the menuScan.dbd file from Base into your own IOC application area,
modify it as you need and add it to your IOC's Makefile like this
    DBD += menuScan.dbd
The local copy will override the version of the file in Base.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Add choice to dbd file Bruno Santos
Re: Add choice to dbd file Andrew Johnson
Prev: Re: Add choice to dbd file Andrew Johnson
Next: FW: Gige performance increasing. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Add choice to dbd file Emmanuel Mayssat
