I believe it uses TCP (it communicates via an ethernet connection). Below is my start up script. I got this IOC after it had been compiled on another machine, so it is quite possible I missed changing something. #!../../bin/linux-x86/genesys cd ../.. dbLoadDatabase("dbd/genesys.dbd") genesys_registerRecordDeviceDriver(pdbbase) ## Location of stream protocol files epicsEnvSet "STREAM_PROTOCOL_PATH", "iocBoot/soft-iocps/" dbLoadRecords("db/genesysPSAll.db") drvAsynIPPortConfigure("GEN8-180-88Z", "130.199.60.184:8003",0,0,0) iocInit() # Start sequences seq(&psControl,"ps=GEN8-180-88Z") I know the IP is right for the drvAsynIPPortConfigure, but I don't know if 8003 is correct. Thank you James On Mon, Apr 22, 2013 at 11:05 AM, Mark Rivers <[email protected]> wrote: Can you explain the interface to the power supply? It is serial, TCP, etc.
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
