1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Add choice to dbd file
To: Emmanuel Mayssat <[email protected]>
Cc: Bruno Santos <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Apr 2013 10:05:41 -0500
Hi Emmanuel,
On 2013-04-22 Emmanuel Mayssat wrote:
> Just out of curiosity, how does epics knows that "60 seconds" is actually
> 60 * 1 second.  In other words, what if I write in my dbd file
>   choice(menuScan60_second,"1 minute")
> or
>   choice(menuScan1_minute,"1 minute")
> Why are those entries different from
>   choice(menuScan60_second,"60 second")
Eric's answer was correct for EPICS versions up to 3.14.  With 3.15 though you
can write any of these and it'll understand you, because the code that parses
the periodic choice strings looks at the units as well as the number:
    choice(menuScan1_hour,      "1 hour")
    choice(menuScan0_5_hours, "0.5 hours")
    choice(menuScan15_minutes, "15 minutes")
    choice(menuScan1_minute,    "1 minute")
    choice(menuScan5_seconds,   "5 seconds")
    choice(menuScan2_seconds,   "2")  # seconds if no units given
    choice(menuScan1_second,    "1 second")
    choice(menuScan2_Hertz,     "2 Hertz")
    choice(menuScan10_Hertz,   "10 Hz")
English only though I'm afraid, and adding units involves editing the code so
I don't recommend that.  You will get a warning if the scan delay is too small
for the OS.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Add choice to dbd file Bruno Santos
Re: Add choice to dbd file Andrew Johnson
RE: Add choice to dbd file Emmanuel Mayssat
Prev: RE: caget delays Mark Rivers
Next: Re: Calling ca_context_create(1) too late Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Add choice to dbd file Eric Norum
Next: FW: Gige performance increasing. Mark Rivers
