1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: the cheksum of Streamdevice
To: [email protected]
Date: Fri, 26 Apr 2013 17:19:43 +0200
Hello Chunlei
On 23.04.2013 15:17, 于春蕾 wrote:
Hi all,
Recently I try to use Streamdevice to control a power supply, but the
protocal of this power supply is very special, especially the check.
The checksum is similar to LRC but different, here is the example.
*Field name ASCII Hex*
start character : 3A
slave address 01 30 31
command code 03 30 33
read data1 high 04 30 34
read data1 low 01 30 31
read data2 high 00 30 30
read data2 low 01 30 31
LRC checksum F6 46 36
End mark CR LF ; 0D 0A
The calculation of LRC checksum is as followed. First, SUM
=01+03+04+01+00+01=0a(hex). Then, LRC checksum is the negative of SUM,
so the checksum is F6(ASCII). I use %<01negsum>, but the calculation of
SUM is 30+31+30+33+30+34+30+31+30+30+30+31, so the checksum is error.
According to %<hexsum>, I want to try %<01hexnegsum>, but it shows
unkown cheksum algorithm. What can I do with this kind of checksum, I am
so anxious.
Thanks very much and best wishes!
Chunlei
I have re-worked the Checksum converter, so that now all algorithms can be prefixed with -,neg, or n for negative sums or with ~ or not for inverted sums.
The code is attached.
Now, your protocol should work with %01<-hexsum8> (or even %0<-hexsum8>, because the leading : is ignored by hexsum8 anyway).
Best regards,
Dirk
* StreamDevice Support                                         *
* (C) 1999 Dirk Zimoch ([email protected])          *
* (C) 2006 Dirk Zimoch ([email protected])                    *
* This is the checksum pseudo-converter of StreamDevice.       *
* Please refer to the HTML files in ../doc/ for a detailed     *
* documentation.                                               *
* If you do any changes in this file, you are not allowed to   *
* redistribute it any more. If there is a bug or a missing     *
* feature, send me an email and/or your patch. If I accept     *
* your changes, they will go to the next release.              *
* DISCLAIMER: If this software breaks something or harms       *
* someone, it's your problem.                                  *
#include "StreamFormatConverter.h"
#include "StreamError.h"
#if defined(__vxworks) || defined(vxWorks) || defined(_WIN32) || defined(__rtems__)
// These systems have no strncasecmp
#include <epicsString.h>
#define strncasecmp epicsStrnCaseCmp
#endif
#include <ctype.h>
typedef unsigned int (*checksumFunc)(const unsigned char* data, unsigned int len,  unsigned int init);
static unsigned int sum(const unsigned char* data, unsigned int len, unsigned int sum)
    while (len--)
        sum += *data++;
    return sum;
static unsigned int xor8(const unsigned char* data, unsigned int len, unsigned int sum)
    while (len--)
        sum ^= *data++;
    return sum;
static unsigned int xor7(const unsigned char* data, unsigned int len, unsigned int sum)
    return xor8(data, len, sum) & 0x7F;
static unsigned int crc_0x07(const unsigned char* data, unsigned int len, unsigned int crc)
    // x^8 + x^2 + x^1 + x^0 (0x07)
    const static unsigned char table[256] = {
        0x00, 0x07, 0x0E, 0x09, 0x1C, 0x1B, 0x12, 0x15,
        0x38, 0x3F, 0x36, 0x31, 0x24, 0x23, 0x2A, 0x2D,
        0x70, 0x77, 0x7E, 0x79, 0x6C, 0x6B, 0x62, 0x65,
        0x48, 0x4F, 0x46, 0x41, 0x54, 0x53, 0x5A, 0x5D,
        0xE0, 0xE7, 0xEE, 0xE9, 0xFC, 0xFB, 0xF2, 0xF5,
        0xD8, 0xDF, 0xD6, 0xD1, 0xC4, 0xC3, 0xCA, 0xCD,
        0x90, 0x97, 0x9E, 0x99, 0x8C, 0x8B, 0x82, 0x85,
        0xA8, 0xAF, 0xA6, 0xA1, 0xB4, 0xB3, 0xBA, 0xBD,
        0xC7, 0xC0, 0xC9, 0xCE, 0xDB, 0xDC, 0xD5, 0xD2,
        0xFF, 0xF8, 0xF1, 0xF6, 0xE3, 0xE4, 0xED, 0xEA,
        0xB7, 0xB0, 0xB9, 0xBE, 0xAB, 0xAC, 0xA5, 0xA2,
        0x8F, 0x88, 0x81, 0x86, 0x93, 0x94, 0x9D, 0x9A,
        0x27, 0x20, 0x29, 0x2E, 0x3B, 0x3C, 0x35, 0x32,
        0x1F, 0x18, 0x11, 0x16, 0x03, 0x04, 0x0D, 0x0A,
        0x57, 0x50, 0x59, 0x5E, 0x4B, 0x4C, 0x45, 0x42,
        0x6F, 0x68, 0x61, 0x66, 0x73, 0x74, 0x7D, 0x7A,
        0x89, 0x8E, 0x87, 0x80, 0x95, 0x92, 0x9B, 0x9C,
        0xB1, 0xB6, 0xBF, 0xB8, 0xAD, 0xAA, 0xA3, 0xA4,
        0xF9, 0xFE, 0xF7, 0xF0, 0xE5, 0xE2, 0xEB, 0xEC,
        0xC1, 0xC6, 0xCF, 0xC8, 0xDD, 0xDA, 0xD3, 0xD4,
        0x69, 0x6E, 0x67, 0x60, 0x75, 0x72, 0x7B, 0x7C,
        0x51, 0x56, 0x5F, 0x58, 0x4D, 0x4A, 0x43, 0x44,
        0x19, 0x1E, 0x17, 0x10, 0x05, 0x02, 0x0B, 0x0C,
        0x21, 0x26, 0x2F, 0x28, 0x3D, 0x3A, 0x33, 0x34,
        0x4E, 0x49, 0x40, 0x47, 0x52, 0x55, 0x5C, 0x5B,
        0x76, 0x71, 0x78, 0x7F, 0x6A, 0x6D, 0x64, 0x63,
        0x3E, 0x39, 0x30, 0x37, 0x22, 0x25, 0x2C, 0x2B,
        0x06, 0x01, 0x08, 0x0F, 0x1A, 0x1D, 0x14, 0x13,
        0xAE, 0xA9, 0xA0, 0xA7, 0xB2, 0xB5, 0xBC, 0xBB,
        0x96, 0x91, 0x98, 0x9F, 0x8A, 0x8D, 0x84, 0x83,
        0xDE, 0xD9, 0xD0, 0xD7, 0xC2, 0xC5, 0xCC, 0xCB,
        0xE6, 0xE1, 0xE8, 0xEF, 0xFA, 0xFD, 0xF4, 0xF3 };
    while (len--) crc = table[(crc ^ *data++) & 0xFF];
    return crc;
static unsigned int crc_0x31(const unsigned char* data, unsigned int len, unsigned int crc)
    // x^8 + x^5 + x^4 + x^0 (0x31)
        0x00, 0x5e, 0xbc, 0xe2, 0x61, 0x3f, 0xdd, 0x83,
        0xc2, 0x9c, 0x7e, 0x20, 0xa3, 0xfd, 0x1f, 0x41,
        0x9d, 0xc3, 0x21, 0x7f, 0xfc, 0xa2, 0x40, 0x1e,
        0x5f, 0x01, 0xe3, 0xbd, 0x3e, 0x60, 0x82, 0xdc,
        0x23, 0x7d, 0x9f, 0xc1, 0x42, 0x1c, 0xfe, 0xa0,
        0xe1, 0xbf, 0x5d, 0x03, 0x80, 0xde, 0x3c, 0x62,
        0xbe, 0xe0, 0x02, 0x5c, 0xdf, 0x81, 0x63, 0x3d,
        0x7c, 0x22, 0xc0, 0x9e, 0x1d, 0x43, 0xa1, 0xff,
        0x46, 0x18, 0xfa, 0xa4, 0x27, 0x79, 0x9b, 0xc5,
        0x84, 0xda, 0x38, 0x66, 0xe5, 0xbb, 0x59, 0x07,
        0xdb, 0x85, 0x67, 0x39, 0xba, 0xe4, 0x06, 0x58,
        0x19, 0x47, 0xa5, 0xfb, 0x78, 0x26, 0xc4, 0x9a,
        0x65, 0x3b, 0xd9, 0x87, 0x04, 0x5a, 0xb8, 0xe6,
        0xa7, 0xf9, 0x1b, 0x45, 0xc6, 0x98, 0x7a, 0x24,
        0xf8, 0xa6, 0x44, 0x1a, 0x99, 0xc7, 0x25, 0x7b,
        0x3a, 0x64, 0x86, 0xd8, 0x5b, 0x05, 0xe7, 0xb9,
        0x8c, 0xd2, 0x30, 0x6e, 0xed, 0xb3, 0x51, 0x0f,
        0x4e, 0x10, 0xf2, 0xac, 0x2f, 0x71, 0x93, 0xcd,
        0x11, 0x4f, 0xad, 0xf3, 0x70, 0x2e, 0xcc, 0x92,
        0xd3, 0x8d, 0x6f, 0x31, 0xb2, 0xec, 0x0e, 0x50,
        0xaf, 0xf1, 0x13, 0x4d, 0xce, 0x90, 0x72, 0x2c,
        0x6d, 0x33, 0xd1, 0x8f, 0x0c, 0x52, 0xb0, 0xee,
        0x32, 0x6c, 0x8e, 0xd0, 0x53, 0x0d, 0xef, 0xb1,
        0xf0, 0xae, 0x4c, 0x12, 0x91, 0xcf, 0x2d, 0x73,
        0xca, 0x94, 0x76, 0x28, 0xab, 0xf5, 0x17, 0x49,
        0x08, 0x56, 0xb4, 0xea, 0x69, 0x37, 0xd5, 0x8b,
        0x57, 0x09, 0xeb, 0xb5, 0x36, 0x68, 0x8a, 0xd4,
        0x95, 0xcb, 0x29, 0x77, 0xf4, 0xaa, 0x48, 0x16,
        0xe9, 0xb7, 0x55, 0x0b, 0x88, 0xd6, 0x34, 0x6a,
        0x2b, 0x75, 0x97, 0xc9, 0x4a, 0x14, 0xf6, 0xa8,
        0x74, 0x2a, 0xc8, 0x96, 0x15, 0x4b, 0xa9, 0xf7,
        0xb6, 0xe8, 0x0a, 0x54, 0xd7, 0x89, 0x6b, 0x35 };
    return crc;
static unsigned int crc_0x8005(const unsigned char* data, unsigned int len, unsigned int crc)
    // x^16 + x^15 + x^2 + x^0  (0x8005)
    const static unsigned short table[256] = {
        0x0000,0x8005,0x800f,0x000a,0x801b,0x001e,0x0014,0x8011,
        0x8033,0x0036,0x003c,0x8039,0x0028,0x802d,0x8027,0x0022,
        0x8063,0x0066,0x006c,0x8069,0x0078,0x807d,0x8077,0x0072,
        0x0050,0x8055,0x805f,0x005a,0x804b,0x004e,0x0044,0x8041,
        0x80c3,0x00c6,0x00cc,0x80c9,0x00d8,0x80dd,0x80d7,0x00d2,
        0x00f0,0x80f5,0x80ff,0x00fa,0x80eb,0x00ee,0x00e4,0x80e1,
        0x00a0,0x80a5,0x80af,0x00aa,0x80bb,0x00be,0x00b4,0x80b1,
        0x8093,0x0096,0x009c,0x8099,0x0088,0x808d,0x8087,0x0082,
        0x8183,0x0186,0x018c,0x8189,0x0198,0x819d,0x8197,0x0192,
        0x01b0,0x81b5,0x81bf,0x01ba,0x81ab,0x01ae,0x01a4,0x81a1,
        0x01e0,0x81e5,0x81ef,0x01ea,0x81fb,0x01fe,0x01f4,0x81f1,
        0x81d3,0x01d6,0x01dc,0x81d9,0x01c8,0x81cd,0x81c7,0x01c2,
        0x0140,0x8145,0x814f,0x014a,0x815b,0x015e,0x0154,0x8151,
        0x8173,0x0176,0x017c,0x8179,0x0168,0x816d,0x8167,0x0162,
        0x8123,0x0126,0x012c,0x8129,0x0138,0x813d,0x8137,0x0132,
        0x0110,0x8115,0x811f,0x011a,0x810b,0x010e,0x0104,0x8101,
        0x8303,0x0306,0x030c,0x8309,0x0318,0x831d,0x8317,0x0312,
        0x0330,0x8335,0x833f,0x033a,0x832b,0x032e,0x0324,0x8321,
        0x0360,0x8365,0x836f,0x036a,0x837b,0x037e,0x0374,0x8371,
        0x8353,0x0356,0x035c,0x8359,0x0348,0x834d,0x8347,0x0342,
        0x03c0,0x83c5,0x83cf,0x03ca,0x83db,0x03de,0x03d4,0x83d1,
        0x83f3,0x03f6,0x03fc,0x83f9,0x03e8,0x83ed,0x83e7,0x03e2,
        0x83a3,0x03a6,0x03ac,0x83a9,0x03b8,0x83bd,0x83b7,0x03b2,
        0x0390,0x8395,0x839f,0x039a,0x838b,0x038e,0x0384,0x8381,
        0x0280,0x8285,0x828f,0x028a,0x829b,0x029e,0x0294,0x8291,
        0x82b3,0x02b6,0x02bc,0x82b9,0x02a8,0x82ad,0x82a7,0x02a2,
        0x82e3,0x02e6,0x02ec,0x82e9,0x02f8,0x82fd,0x82f7,0x02f2,
        0x02d0,0x82d5,0x82df,0x02da,0x82cb,0x02ce,0x02c4,0x82c1,
        0x8243,0x0246,0x024c,0x8249,0x0258,0x825d,0x8257,0x0252,
        0x0270,0x8275,0x827f,0x027a,0x826b,0x026e,0x0264,0x8261,
        0x0220,0x8225,0x822f,0x022a,0x823b,0x023e,0x0234,0x8231,
        0x8213,0x0216,0x021c,0x8219,0x0208,0x820d,0x8207,0x0202 };
    while (len--) crc = table[((crc>>8) ^ *data++) & 0xFF] ^ (crc << 8);
    return crc;
static unsigned int crc_0x8005_r(const unsigned char* data, unsigned int len, unsigned int crc)
    // reflected
        0x0000,0xC0C1,0xC181,0x0140,0xC301,0x03C0,0x0280,0xC241,
        0xC601,0x06C0,0x0780,0xC741,0x0500,0xC5C1,0xC481,0x0440,
        0xCC01,0x0CC0,0x0D80,0xCD41,0x0F00,0xCFC1,0xCE81,0x0E40,
        0x0A00,0xCAC1,0xCB81,0x0B40,0xC901,0x09C0,0x0880,0xC841,
        0xD801,0x18C0,0x1980,0xD941,0x1B00,0xDBC1,0xDA81,0x1A40,
        0x1E00,0xDEC1,0xDF81,0x1F40,0xDD01,0x1DC0,0x1C80,0xDC41,
        0x1400,0xD4C1,0xD581,0x1540,0xD701,0x17C0,0x1680,0xD641,
        0xD201,0x12C0,0x1380,0xD341,0x1100,0xD1C1,0xD081,0x1040,
        0xF001,0x30C0,0x3180,0xF141,0x3300,0xF3C1,0xF281,0x3240,
        0x3600,0xF6C1,0xF781,0x3740,0xF501,0x35C0,0x3480,0xF441,
        0x3C00,0xFCC1,0xFD81,0x3D40,0xFF01,0x3FC0,0x3E80,0xFE41,
        0xFA01,0x3AC0,0x3B80,0xFB41,0x3900,0xF9C1,0xF881,0x3840,
        0x2800,0xE8C1,0xE981,0x2940,0xEB01,0x2BC0,0x2A80,0xEA41,
        0xEE01,0x2EC0,0x2F80,0xEF41,0x2D00,0xEDC1,0xEC81,0x2C40,
        0xE401,0x24C0,0x2580,0xE541,0x2700,0xE7C1,0xE681,0x2640,
        0x2200,0xE2C1,0xE381,0x2340,0xE101,0x21C0,0x2080,0xE041,
        0xA001,0x60C0,0x6180,0xA141,0x6300,0xA3C1,0xA281,0x6240,
        0x6600,0xA6C1,0xA781,0x6740,0xA501,0x65C0,0x6480,0xA441,
        0x6C00,0xACC1,0xAD81,0x6D40,0xAF01,0x6FC0,0x6E80,0xAE41,
        0xAA01,0x6AC0,0x6B80,0xAB41,0x6900,0xA9C1,0xA881,0x6840,
        0x7800,0xB8C1,0xB981,0x7940,0xBB01,0x7BC0,0x7A80,0xBA41,
        0xBE01,0x7EC0,0x7F80,0xBF41,0x7D00,0xBDC1,0xBC81,0x7C40,
        0xB401,0x74C0,0x7580,0xB541,0x7700,0xB7C1,0xB681,0x7640,
        0x7200,0xB2C1,0xB381,0x7340,0xB101,0x71C0,0x7080,0xB041,
        0x5000,0x90C1,0x9181,0x5140,0x9301,0x53C0,0x5280,0x9241,
        0x9601,0x56C0,0x5780,0x9741,0x5500,0x95C1,0x9481,0x5440,
        0x9C01,0x5CC0,0x5D80,0x9D41,0x5F00,0x9FC1,0x9E81,0x5E40,
        0x5A00,0x9AC1,0x9B81,0x5B40,0x9901,0x59C0,0x5880,0x9841,
        0x8801,0x48C0,0x4980,0x8941,0x4B00,0x8BC1,0x8A81,0x4A40,
        0x4E00,0x8EC1,0x8F81,0x4F40,0x8D01,0x4DC0,0x4C80,0x8C41,
        0x4400,0x84C1,0x8581,0x4540,0x8701,0x47C0,0x4680,0x8641,
        0x8201,0x42C0,0x4380,0x8341,0x4100,0x81C1,0x8081,0x4040 };
    while (len--) crc = table[(crc ^ *data++) & 0xFF] ^ (crc >> 8);
    return crc;
static unsigned int crc_0x1021(const unsigned char* data, unsigned int len, unsigned int crc)
    // x^16 + x^12 + x^5 + x^0 (0x1021)
      0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50A5, 0x60C6, 0x70E7,
      0x8108, 0x9129, 0xA14A, 0xB16B, 0xC18C, 0xD1AD, 0xE1CE, 0xF1EF,
      0x1231, 0x0210, 0x3273, 0x2252, 0x52B5, 0x4294, 0x72F7, 0x62D6,
      0x9339, 0x8318, 0xB37B, 0xA35A, 0xD3BD, 0xC39C, 0xF3FF, 0xE3DE,
      0x2462, 0x3443, 0x0420, 0x1401, 0x64E6, 0x74C7, 0x44A4, 0x5485,
      0xA56A, 0xB54B, 0x8528, 0x9509, 0xE5EE, 0xF5CF, 0xC5AC, 0xD58D,
      0x3653, 0x2672, 0x1611, 0x0630, 0x76D7, 0x66F6, 0x5695, 0x46B4,
      0xB75B, 0xA77A, 0x9719, 0x8738, 0xF7DF, 0xE7FE, 0xD79D, 0xC7BC,
      0x48C4, 0x58E5, 0x6886, 0x78A7, 0x0840, 0x1861, 0x2802, 0x3823,
      0xC9CC, 0xD9ED, 0xE98E, 0xF9AF, 0x8948, 0x9969, 0xA90A, 0xB92B,
      0x5AF5, 0x4AD4, 0x7AB7, 0x6A96, 0x1A71, 0x0A50, 0x3A33, 0x2A12,
      0xDBFD, 0xCBDC, 0xFBBF, 0xEB9E, 0x9B79, 0x8B58, 0xBB3B, 0xAB1A,
      0x6CA6, 0x7C87, 0x4CE4, 0x5CC5, 0x2C22, 0x3C03, 0x0C60, 0x1C41,
      0xEDAE, 0xFD8F, 0xCDEC, 0xDDCD, 0xAD2A, 0xBD0B, 0x8D68, 0x9D49,
      0x7E97, 0x6EB6, 0x5ED5, 0x4EF4, 0x3E13, 0x2E32, 0x1E51, 0x0E70,
      0xFF9F, 0xEFBE, 0xDFDD, 0xCFFC, 0xBF1B, 0xAF3A, 0x9F59, 0x8F78,
      0x9188, 0x81A9, 0xB1CA, 0xA1EB, 0xD10C, 0xC12D, 0xF14E, 0xE16F,
      0x1080, 0x00A1, 0x30C2, 0x20E3, 0x5004, 0x4025, 0x7046, 0x6067,
      0x83B9, 0x9398, 0xA3FB, 0xB3DA, 0xC33D, 0xD31C, 0xE37F, 0xF35E,
      0x02B1, 0x1290, 0x22F3, 0x32D2, 0x4235, 0x5214, 0x6277, 0x7256,
      0xB5EA, 0xA5CB, 0x95A8, 0x8589, 0xF56E, 0xE54F, 0xD52C, 0xC50D,
      0x34E2, 0x24C3, 0x14A0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
      0xA7DB, 0xB7FA, 0x8799, 0x97B8, 0xE75F, 0xF77E, 0xC71D, 0xD73C,
      0x26D3, 0x36F2, 0x0691, 0x16B0, 0x6657, 0x7676, 0x4615, 0x5634,
      0xD94C, 0xC96D, 0xF90E, 0xE92F, 0x99C8, 0x89E9, 0xB98A, 0xA9AB,
      0x5844, 0x4865, 0x7806, 0x6827, 0x18C0, 0x08E1, 0x3882, 0x28A3,
      0xCB7D, 0xDB5C, 0xEB3F, 0xFB1E, 0x8BF9, 0x9BD8, 0xABBB, 0xBB9A,
      0x4A75, 0x5A54, 0x6A37, 0x7A16, 0x0AF1, 0x1AD0, 0x2AB3, 0x3A92,
      0xFD2E, 0xED0F, 0xDD6C, 0xCD4D, 0xBDAA, 0xAD8B, 0x9DE8, 0x8DC9,
      0x7C26, 0x6C07, 0x5C64, 0x4C45, 0x3CA2, 0x2C83, 0x1CE0, 0x0CC1,
      0xEF1F, 0xFF3E, 0xCF5D, 0xDF7C, 0xAF9B, 0xBFBA, 0x8FD9, 0x9FF8,
      0x6E17, 0x7E36, 0x4E55, 0x5E74, 0x2E93, 0x3EB2, 0x0ED1, 0x1EF0 };
    return crc;
static unsigned int crc_0x04C11DB7(const unsigned char* data, unsigned int len, unsigned int crc)
    // x^32 + x^26 + x^23 + x^22 + x^16 + x^12 + x^11 + x^10 +
    //    x^8 + x^7 + x^5 + x^4 + x^2 + x^1 + x^0  (0x04C11DB7)
    const static unsigned int table[] = {
        0x00000000, 0x04c11db7, 0x09823b6e, 0x0d4326d9,
        0x130476dc, 0x17c56b6b, 0x1a864db2, 0x1e475005,
        0x2608edb8, 0x22c9f00f, 0x2f8ad6d6, 0x2b4bcb61,
        0x350c9b64, 0x31cd86d3, 0x3c8ea00a, 0x384fbdbd,
        0x4c11db70, 0x48d0c6c7, 0x4593e01e, 0x4152fda9,
        0x5f15adac, 0x5bd4b01b, 0x569796c2, 0x52568b75,
        0x6a1936c8, 0x6ed82b7f, 0x639b0da6, 0x675a1011,
        0x791d4014, 0x7ddc5da3, 0x709f7b7a, 0x745e66cd,
        0x9823b6e0, 0x9ce2ab57, 0x91a18d8e, 0x95609039,
        0x8b27c03c, 0x8fe6dd8b, 0x82a5fb52, 0x8664e6e5,
        0xbe2b5b58, 0xbaea46ef, 0xb7a96036, 0xb3687d81,
        0xad2f2d84, 0xa9ee3033, 0xa4ad16ea, 0xa06c0b5d,
        0xd4326d90, 0xd0f37027, 0xddb056fe, 0xd9714b49,
        0xc7361b4c, 0xc3f706fb, 0xceb42022, 0xca753d95,
        0xf23a8028, 0xf6fb9d9f, 0xfbb8bb46, 0xff79a6f1,
        0xe13ef6f4, 0xe5ffeb43, 0xe8bccd9a, 0xec7dd02d,
        0x34867077, 0x30476dc0, 0x3d044b19, 0x39c556ae,
        0x278206ab, 0x23431b1c, 0x2e003dc5, 0x2ac12072,
        0x128e9dcf, 0x164f8078, 0x1b0ca6a1, 0x1fcdbb16,
        0x018aeb13, 0x054bf6a4, 0x0808d07d, 0x0cc9cdca,
        0x7897ab07, 0x7c56b6b0, 0x71159069, 0x75d48dde,
        0x6b93dddb, 0x6f52c06c, 0x6211e6b5, 0x66d0fb02,
        0x5e9f46bf, 0x5a5e5b08, 0x571d7dd1, 0x53dc6066,
        0x4d9b3063, 0x495a2dd4, 0x44190b0d, 0x40d816ba,
        0xaca5c697, 0xa864db20, 0xa527fdf9, 0xa1e6e04e,
        0xbfa1b04b, 0xbb60adfc, 0xb6238b25, 0xb2e29692,
        0x8aad2b2f, 0x8e6c3698, 0x832f1041, 0x87ee0df6,
        0x99a95df3, 0x9d684044, 0x902b669d, 0x94ea7b2a,
        0xe0b41de7, 0xe4750050, 0xe9362689, 0xedf73b3e,
        0xf3b06b3b, 0xf771768c, 0xfa325055, 0xfef34de2,
        0xc6bcf05f, 0xc27dede8, 0xcf3ecb31, 0xcbffd686,
        0xd5b88683, 0xd1799b34, 0xdc3abded, 0xd8fba05a,
        0x690ce0ee, 0x6dcdfd59, 0x608edb80, 0x644fc637,
        0x7a089632, 0x7ec98b85, 0x738aad5c, 0x774bb0eb,
        0x4f040d56, 0x4bc510e1, 0x46863638, 0x42472b8f,
        0x5c007b8a, 0x58c1663d, 0x558240e4, 0x51435d53,
        0x251d3b9e, 0x21dc2629, 0x2c9f00f0, 0x285e1d47,
        0x36194d42, 0x32d850f5, 0x3f9b762c, 0x3b5a6b9b,
        0x0315d626, 0x07d4cb91, 0x0a97ed48, 0x0e56f0ff,
        0x1011a0fa, 0x14d0bd4d, 0x19939b94, 0x1d528623,
        0xf12f560e, 0xf5ee4bb9, 0xf8ad6d60, 0xfc6c70d7,
        0xe22b20d2, 0xe6ea3d65, 0xeba91bbc, 0xef68060b,
        0xd727bbb6, 0xd3e6a601, 0xdea580d8, 0xda649d6f,
        0xc423cd6a, 0xc0e2d0dd, 0xcda1f604, 0xc960ebb3,
        0xbd3e8d7e, 0xb9ff90c9, 0xb4bcb610, 0xb07daba7,
        0xae3afba2, 0xaafbe615, 0xa7b8c0cc, 0xa379dd7b,
        0x9b3660c6, 0x9ff77d71, 0x92b45ba8, 0x9675461f,
        0x8832161a, 0x8cf30bad, 0x81b02d74, 0x857130c3,
        0x5d8a9099, 0x594b8d2e, 0x5408abf7, 0x50c9b640,
        0x4e8ee645, 0x4a4ffbf2, 0x470cdd2b, 0x43cdc09c,
        0x7b827d21, 0x7f436096, 0x7200464f, 0x76c15bf8,
        0x68860bfd, 0x6c47164a, 0x61043093, 0x65c52d24,
        0x119b4be9, 0x155a565e, 0x18197087, 0x1cd86d30,
        0x029f3d35, 0x065e2082, 0x0b1d065b, 0x0fdc1bec,
        0x3793a651, 0x3352bbe6, 0x3e119d3f, 0x3ad08088,
        0x2497d08d, 0x2056cd3a, 0x2d15ebe3, 0x29d4f654,
        0xc5a92679, 0xc1683bce, 0xcc2b1d17, 0xc8ea00a0,
        0xd6ad50a5, 0xd26c4d12, 0xdf2f6bcb, 0xdbee767c,
        0xe3a1cbc1, 0xe760d676, 0xea23f0af, 0xeee2ed18,
        0xf0a5bd1d, 0xf464a0aa, 0xf9278673, 0xfde69bc4,
        0x89b8fd09, 0x8d79e0be, 0x803ac667, 0x84fbdbd0,
        0x9abc8bd5, 0x9e7d9662, 0x933eb0bb, 0x97ffad0c,
        0xafb010b1, 0xab710d06, 0xa6322bdf, 0xa2f33668,
        0xbcb4666d, 0xb8757bda, 0xb5365d03, 0xb1f740b4 };
    while (len--) crc = table[((crc>>24) ^ *data++) & 0xFF] ^ (crc << 8);
    return crc;
static unsigned int crc_0x04C11DB7_r(const unsigned char* data, unsigned int len, unsigned int crc)
    // reflected
        0x00000000, 0x77073096, 0xee0e612c, 0x990951ba,
        0x076dc419, 0x706af48f, 0xe963a535, 0x9e6495a3,
        0x0edb8832, 0x79dcb8a4, 0xe0d5e91e, 0x97d2d988,
        0x09b64c2b, 0x7eb17cbd, 0xe7b82d07, 0x90bf1d91,
        0x1db71064, 0x6ab020f2, 0xf3b97148, 0x84be41de,
        0x1adad47d, 0x6ddde4eb, 0xf4d4b551, 0x83d385c7,
        0x136c9856, 0x646ba8c0, 0xfd62f97a, 0x8a65c9ec,
        0x14015c4f, 0x63066cd9, 0xfa0f3d63, 0x8d080df5,
        0x3b6e20c8, 0x4c69105e, 0xd56041e4, 0xa2677172,
        0x3c03e4d1, 0x4b04d447, 0xd20d85fd, 0xa50ab56b,
        0x35b5a8fa, 0x42b2986c, 0xdbbbc9d6, 0xacbcf940,
        0x32d86ce3, 0x45df5c75, 0xdcd60dcf, 0xabd13d59,
        0x26d930ac, 0x51de003a, 0xc8d75180, 0xbfd06116,
        0x21b4f4b5, 0x56b3c423, 0xcfba9599, 0xb8bda50f,
        0x2802b89e, 0x5f058808, 0xc60cd9b2, 0xb10be924,
        0x2f6f7c87, 0x58684c11, 0xc1611dab, 0xb6662d3d,
        0x76dc4190, 0x01db7106, 0x98d220bc, 0xefd5102a,
        0x71b18589, 0x06b6b51f, 0x9fbfe4a5, 0xe8b8d433,
        0x7807c9a2, 0x0f00f934, 0x9609a88e, 0xe10e9818,
        0x7f6a0dbb, 0x086d3d2d, 0x91646c97, 0xe6635c01,
        0x6b6b51f4, 0x1c6c6162, 0x856530d8, 0xf262004e,
        0x6c0695ed, 0x1b01a57b, 0x8208f4c1, 0xf50fc457,
        0x65b0d9c6, 0x12b7e950, 0x8bbeb8ea, 0xfcb9887c,
        0x62dd1ddf, 0x15da2d49, 0x8cd37cf3, 0xfbd44c65,
        0x4db26158, 0x3ab551ce, 0xa3bc0074, 0xd4bb30e2,
        0x4adfa541, 0x3dd895d7, 0xa4d1c46d, 0xd3d6f4fb,
        0x4369e96a, 0x346ed9fc, 0xad678846, 0xda60b8d0,
        0x44042d73, 0x33031de5, 0xaa0a4c5f, 0xdd0d7cc9,
        0x5005713c, 0x270241aa, 0xbe0b1010, 0xc90c2086,
        0x5768b525, 0x206f85b3, 0xb966d409, 0xce61e49f,
        0x5edef90e, 0x29d9c998, 0xb0d09822, 0xc7d7a8b4,
        0x59b33d17, 0x2eb40d81, 0xb7bd5c3b, 0xc0ba6cad,
        0xedb88320, 0x9abfb3b6, 0x03b6e20c, 0x74b1d29a,
        0xead54739, 0x9dd277af, 0x04db2615, 0x73dc1683,
        0xe3630b12, 0x94643b84, 0x0d6d6a3e, 0x7a6a5aa8,
        0xe40ecf0b, 0x9309ff9d, 0x0a00ae27, 0x7d079eb1,
        0xf00f9344, 0x8708a3d2, 0x1e01f268, 0x6906c2fe,
        0xf762575d, 0x806567cb, 0x196c3671, 0x6e6b06e7,
        0xfed41b76, 0x89d32be0, 0x10da7a5a, 0x67dd4acc,
        0xf9b9df6f, 0x8ebeeff9, 0x17b7be43, 0x60b08ed5,
        0xd6d6a3e8, 0xa1d1937e, 0x38d8c2c4, 0x4fdff252,
        0xd1bb67f1, 0xa6bc5767, 0x3fb506dd, 0x48b2364b,
        0xd80d2bda, 0xaf0a1b4c, 0x36034af6, 0x41047a60,
        0xdf60efc3, 0xa867df55, 0x316e8eef, 0x4669be79,
        0xcb61b38c, 0xbc66831a, 0x256fd2a0, 0x5268e236,
        0xcc0c7795, 0xbb0b4703, 0x220216b9, 0x5505262f,
        0xc5ba3bbe, 0xb2bd0b28, 0x2bb45a92, 0x5cb36a04,
        0xc2d7ffa7, 0xb5d0cf31, 0x2cd99e8b, 0x5bdeae1d,
        0x9b64c2b0, 0xec63f226, 0x756aa39c, 0x026d930a,
        0x9c0906a9, 0xeb0e363f, 0x72076785, 0x05005713,
        0x95bf4a82, 0xe2b87a14, 0x7bb12bae, 0x0cb61b38,
        0x92d28e9b, 0xe5d5be0d, 0x7cdcefb7, 0x0bdbdf21,
        0x86d3d2d4, 0xf1d4e242, 0x68ddb3f8, 0x1fda836e,
        0x81be16cd, 0xf6b9265b, 0x6fb077e1, 0x18b74777,
        0x88085ae6, 0xff0f6a70, 0x66063bca, 0x11010b5c,
        0x8f659eff, 0xf862ae69, 0x616bffd3, 0x166ccf45,
        0xa00ae278, 0xd70dd2ee, 0x4e048354, 0x3903b3c2,
        0xa7672661, 0xd06016f7, 0x4969474d, 0x3e6e77db,
        0xaed16a4a, 0xd9d65adc, 0x40df0b66, 0x37d83bf0,
        0xa9bcae53, 0xdebb9ec5, 0x47b2cf7f, 0x30b5ffe9,
        0xbdbdf21c, 0xcabac28a, 0x53b39330, 0x24b4a3a6,
        0xbad03605, 0xcdd70693, 0x54de5729, 0x23d967bf,
        0xb3667a2e, 0xc4614ab8, 0x5d681b02, 0x2a6f2b94,
        0xb40bbe37, 0xc30c8ea1, 0x5a05df1b, 0x2d02ef8d };
    return crc;
static unsigned int adler32(const unsigned char* data, unsigned int len, unsigned int init)
    unsigned int a = init & 0xFFFF;
    unsigned int b = (init >> 16) & 0xFFFF;
    while (len) {
        unsigned int tlen = len > 5550 ? 5550 : len;
        len -= tlen;
        do {
            a += *data++;
            b += a;
        } while (--tlen);
        a = (a & 0xFFFF) + (a >> 16) * 15;
        b = (b & 0xFFFF) + (b >> 16) * 15;
   if (a >= 65521) a -= 65521;
   if (b >= 65521) b -= 65521;
   return b << 16 | a;
static unsigned int hexsum(const unsigned char* data, unsigned int len, unsigned int sum)
    // Add all hex digits, ignore all other bytes.
    unsigned int d;
    while (len--)
        d = toupper(*data++);
        if (isxdigit(d))
            if (isdigit(d)) d -= '0';
            else d -= 'A' - 0x0A;
            sum += d;
    return sum;
struct checksum
    const char* name;
    checksumFunc func;
    unsigned int init;
    unsigned int xorout;
    signed char bytes;
static checksum checksumMap[] =
// You may add your own checksum functions to this map.
//    name      func              init        xorout  bytes  chk("123456789")
    {"sum",     sum,              0x00,       0x00,       1}, // 0xDD
    {"sum8",    sum,              0x00,       0x00,       1}, // 0xDD
    {"sum16",   sum,              0x0000,     0x0000,     2}, // 0x01DD
    {"sum32",   sum,              0x00000000, 0x00000000, 4}, // 0x000001DD
    {"xor",     xor8,             0x00,       0x00,       1}, // 0x31
    {"xor8",    xor8,             0x00,       0x00,       1}, // 0x31
    {"xor7",    xor7,             0x00,       0x00,       1}, // 0x31
    {"crc8",    crc_0x07,         0x00,       0x00,       1}, // 0xF4
    {"ccitt8",  crc_0x31,         0x00,       0x00,       1}, // 0xA1
    {"crc16",   crc_0x8005,       0x0000,     0x0000,     2}, // 0xFEE8
    {"crc16r",  crc_0x8005_r,     0x0000,     0x0000,     2}, // 0xBB3D
    {"ccitt16", crc_0x1021,       0xFFFF,     0x0000,     2}, // 0x29B1
    {"ccitt16a",crc_0x1021,       0x1D0F,     0x0000,     2}, // 0xE5CC
    {"ccitt16x",crc_0x1021,       0x0000,     0x0000,     2}, // 0x31C3
    {"crc16c",  crc_0x1021,       0x0000,     0x0000,     2}, // 0x31C3
    {"xmodem",  crc_0x1021,       0x0000,     0x0000,     2}, // 0x31C3
    {"crc32",   crc_0x04C11DB7,   0xFFFFFFFF, 0xFFFFFFFF, 4}, // 0xFC891918
    {"crc32r",  crc_0x04C11DB7_r, 0xFFFFFFFF, 0xFFFFFFFF, 4}, // 0xCBF43926
    {"jamcrc",  crc_0x04C11DB7_r, 0xFFFFFFFF, 0x00000000, 4}, // 0x340BC6D9
    {"adler32", adler32,          0x00000001, 0x00000000, 4}, // 0x091E01DE
    {"hexsum8", hexsum,           0x00,       0x00,       1}  // 0x2D
static unsigned int mask[5] = {0, 0xFF, 0xFFFF, 0xFFFFFF, 0xFFFFFFFF};
class ChecksumConverter : public StreamFormatConverter
    int parse (const StreamFormat&, StreamBuffer&, const char*&, bool);
    bool printPseudo(const StreamFormat&, StreamBuffer&);
    int scanPseudo(const StreamFormat&, StreamBuffer&, long& cursor);
int ChecksumConverter::
parse(const StreamFormat&, StreamBuffer& info, const char*& source, bool)
    const char* p = strchr(source, '>');
    if (!p)
        error ("Missing closing '>' in checksum format.\n");
        return false;
    bool negflag=false;
    bool notflag=false;
    if (*source == '-')
        source++;
        negflag = true;
    if (strncasecmp(source, "neg", 3) == 0)
        source+=3;
        negflag = true;
    if (*source == '~')
        source++;
        notflag = true;
    if (strncasecmp(source, "not", 3) == 0)
        source+=3;
        notflag = true;
    unsigned  fnum;
    int len = p-source;
    unsigned int init, xorout;
    for (fnum = 0; fnum < sizeof(checksumMap)/sizeof(checksum); fnum++)
        if ((strncasecmp(source, checksumMap[fnum].name, len) == 0) ||
            (*source == 'n' && len > 1 && strncasecmp(source+1, checksumMap[fnum].name, len-1) == 0 && (negflag = true)))
            init = checksumMap[fnum].init;
            xorout = checksumMap[fnum].xorout;
            if (negflag)
                init = ~init;
                xorout = ~xorout;
            if (notflag)
                xorout = ~xorout;
            info.append(&init,  sizeof(init));
            info.append(&xorout, sizeof(xorout));
            info.append(fnum);
            source = p+1;
            return pseudo_format;
    error ("Unknown checksum algorithm \"%.*s\"\n", len, source);
    return false;
bool ChecksumConverter::
printPseudo(const StreamFormat& format, StreamBuffer& output)
    unsigned int sum;
    const char* info = format.info;
    unsigned int init = extract<unsigned int>(info);
    unsigned int xorout = extract<unsigned int>(info);
    int fnum = extract<char>(info);
    int start = format.width;
    int length = output.length()-format.width;
    if (format.prec > 0) length -= format.prec;
    debug("ChecksumConverter %s: output to check: \"%s\"\n",
        checksumMap[fnum].name, output.expand(start,length)());
    sum = (xorout ^ checksumMap[fnum].func(
        reinterpret_cast<unsigned char*>(output(start)), length, init))
        & mask[checksumMap[fnum].bytes];
    debug("ChecksumConverter %s: output checksum is 0x%X\n",
        checksumMap[fnum].name, sum);
    int i;
    unsigned outchar;
    if (format.flags & sign_flag) // decimal
        // get number of decimal digits from number of bytes: ceil(xbytes*2.5)
        i = (checksumMap[fnum].bytes+1)*25/10-2;
        output.print("%0*d", i, sum);
        debug("ChecksumConverter %s: decimal appending %0*d\n",
            checksumMap[fnum].name, i, sum);
    else
    if (format.flags & alt_flag) // lsb first (little endian)
        for (i = 0; i < checksumMap[fnum].bytes; i++)
            outchar = sum & 0xff;
            debug("ChecksumConverter %s: little endian appending 0x%X\n",
                checksumMap[fnum].name, outchar);
            if (format.flags & zero_flag) // ASCII
                output.print("%02X", outchar);
            else
            if (format.flags & left_flag) // poor man's hex: 0x30 - 0x3F
                output.print("%c%c",
                    ((outchar>>4)&0x0f)|0x30, (outchar&0x0f)|0x30);
            else                          // binary
                output.append(outchar);
            sum >>= 8;
    else // msb first (big endian)
        sum <<= 8*(4-checksumMap[fnum].bytes);
            outchar = (sum >> 24) & 0xff;
            debug("ChecksumConverter %s: big endian appending 0x%X\n",
            else
            else                          // binary
            sum <<= 8;
    return true;
scanPseudo(const StreamFormat& format, StreamBuffer& input, long& cursor)
    unsigned int sum;
    int length = cursor-format.width;
    debug("ChecksumConverter %s: input to check: \"%s\n",
        checksumMap[fnum].name, input.expand(start,length)());
    int expectedLength =
        // get number of decimal digits from number of bytes: ceil(bytes*2.5)
        format.flags & sign_flag ? (checksumMap[fnum].bytes + 1) * 25 / 10 - 2 :
        format.flags & (zero_flag|left_flag) ? 2 * checksumMap[fnum].bytes :
    if (input.length() - cursor < expectedLength)
        debug("ChecksumConverter %s: Input '%s' too short for checksum\n",
            checksumMap[fnum].name, input.expand(cursor)());
        return -1;
        reinterpret_cast<unsigned char*>(input(start)), length, init))
    debug("ChecksumConverter %s: input checksum is 0x%0*X\n",
        checksumMap[fnum].name, 2*checksumMap[fnum].bytes, sum);
    int i, j;
    unsigned inchar;
        unsigned int sumin = 0;
        for (i = 0; i < expectedLength; i++)
            inchar = input[cursor+i];
            if (isdigit(inchar)) sumin = sumin*10+inchar-'0';
            else break;
        if (sumin != sum)
            debug("ChecksumConverter %s: Input %0*u does not match checksum %0*u\n",
                checksumMap[fnum].name, i, sumin, expectedLength, sum);
            return -1;
    else
                if (sscanf(input(cursor+2*i), "%2X", &inchar) != 1)
                    debug("ChecksumConverter %s: Input byte '%s' is not a hex byte\n",
                        checksumMap[fnum].name, input.expand(cursor+2*i,2)());
                    return -1;
            else
                if ((input[cursor+2*i] & 0xf0) != 0x30)
                    debug("ChecksumConverter %s: Input byte 0x%02X is not in range 0x30 - 0x3F\n",
                        checksumMap[fnum].name, input[cursor+2*i]);
                    return -1;
                if ((input[cursor+2*i+1] & 0xf0) != 0x30)
                        checksumMap[fnum].name, input[cursor+2*i+1]);
                    return -1;
                inchar = ((input[cursor+2*i] & 0x0f) << 4) | (input[cursor+2*i+1] & 0x0f);
            else                          // binary
                inchar = input[cursor+i] & 0xff;
            if (inchar != ((sum >> 8*i) & 0xff))
                debug("ChecksumConverter %s: Input byte 0x%02X does not match checksum 0x%0*X\n",
                    checksumMap[fnum].name, inchar, 2*checksumMap[fnum].bytes, sum);
                return -1;
        for (i = checksumMap[fnum].bytes-1, j = 0; i >= 0; i--, j++)
                sscanf(input(cursor+2*i), "%2x", &inchar);
            else
                    return -1;
                    return -1;
            else                          // binary
            if (inchar != ((sum >> 8*j) & 0xff))
                return -1;
    return expectedLength;
RegisterConverter (ChecksumConverter, "<");
the cheksum of Streamdevice 于春蕾
Prev: RE: Unable to get a picture from Baumer TXG13 GigE camera Mark Rivers
Next: BNL is denied TCP access by anl Ivashkevych, Oksana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: the cheksum of Streamdevice 于春蕾
Next: asynPrint to print asyn port name ulrik.pedersen
