1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS Extensions Compilation Errors
To: EPICS Tech Talk <[email protected]>
Date: Mon, 29 Apr 2013 10:09:15 +0100
On Mon Apr 29 2013 09:52:20 GMT+0100 (BST), murad ali <[email protected]> wrote:
I have Ubuntu 11.4 Installed. I want to Install EPICS Base and MEDM following Instructions on (Download the distributions tarballs from EPICS.doc attached) . please refer to Configure the Extensions Section in this File.
EPICS Base is Installed and Compiled (Base Installation Attached)
While Compiling MEDM the erorr occures during make (extensions error attached)
kindly let me tell that how can I compile MEDM properly.
Also what are other alternatives to MEDM. CSS is just like MEDM or some other thing.
An Early Response is required
Regards
Murad Ali
If you want to get started fast, try using the binary packages provided by Michael Davidsaver at NSLS-II. They should work on Debian based distributions.
http://epics.nsls2.bnl.gov/debian/
As for the alternatives for MEDM, there are a number of them. Which one is suited best for your application depends on your specific needs.
In general, it is safe to say that EDM is newer than MEDM and has a roughly similar set of features.
~Ralph
EPICS Extensions Compilation Errors murad ali
Prev: EPICS Extensions Compilation Errors murad ali
Next: AW: EPICS Extensions Compilation Errors Zimoch Dirk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
