Hello all, I'm adapting an IOC that reads text files and assigns the values in them to epics variables for a new system. It uses sequencer and I don't think I'm setting up the registrar correctly in the dbd file... I'm not very familiar with sequencer save for the .stt files build the binaries. The old IOC was for a bunch of gas pressure and flow monitor variables for the time of flight detector at STAR. I'm adapting a copy for a cooling system for a new pixel detector that will be installed soon. I'm using epics base 3.13.12.1 and sequencer 2.0.12 The registrar in <top>/dbd/pxlCooling.dbd: registrar(pxlCooling_registrar) make[3]: Entering directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src/O.linux-x86' /usr/bin/g++ -o pxlCooling -L/home/sysuser/epics.3.14.12.1/base-3.14.12.1/lib/linux-x86 -L/home/sysuser/epics/synApps_5_5/support/seq-2-0-12/lib/linux-x86 -Wl,-rpath,/home/sysuser/epics.3.14.12.1/base-3.14.12.1/lib/linux-x86 -Wl,-rpath,/home/sysuser/epics/synApps_5_5/support/seq-2-0-12/lib/linux-x86 -m32 pxlCooling_registerRecordDeviceDriver.o pxlCooling.o pxlCoolingMain.o -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom pxlCooling_registerRecordDeviceDriver.o: In function `pxlCooling_registerRecordDeviceDriver': /home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src/O.linux-x86/pxlCooling_registerRecordDeviceDriver.cpp:291: undefined reference to `pvar_func_pxlCooling_registrar' collect2: ld returned 1 exit status make[3]: *** [pxlCooling] Error 1 make[3]: Leaving directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src/O.linux-x86' make[2]: *** [install.linux-x86] Error 2 make[2]: Leaving directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp/src' make[1]: *** [src.install] Error 2 make[1]: Leaving directory `/home/sysuser/epics.3.14.12.1/hft_sc/pixel/cooling/pxlCoolingApp' make: *** [pxlCoolingApp.install] Error 2 Thank you! James Ross
ANJ, 20 Apr 2015 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
