1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM
To: [email protected]
Date: Fri, 10 May 2013 01:50:37 -0700
Hi Zen,
Are all the other PV's also UDF with SEVR Invalid?
If not, that might explain the difference.
If they're all UDF, it might be due to some setting that's different
on that edm text control widget.
- Bruce
On 5/9/2013 10:05 PM, Zenon Szalata wrote:
I have a peculiar problem which I fail to understand.
I am using EPICS R3.14.12.2, EDM 1-12-56.
I have a few longout records which are created from the same template.
After the IOC is initialized, these longout records have non zero
values.  The records are controlled via EDM Text Control widgets.  At
this point, no user entries were made.  I could explain how these
records got the initial values, but that is probably not relevant.  When
I start an EDM screen which has the Text Controls, one of the controls
shows value of zero.  caget on this record shows a non zero value. I got
the PV name for the caget command by middle clicking on the Text
Control. Yet, all the other Text Controls show the correct non zero
values which are the values that I verified with both caget and dbpr
commands.   The Text Controls were created by copy and paste, all the
records were created from the same template.
Restarting EDM does not help.  Putting EDM in edit mode and back in
execute mode does not help; the value zero is stubbornly displayed and
just for this one PV.
Here is dbpr output for the record in question:
epics> dbpr ESA:LO:SC:2531-21:CH1:MAXV-WR:DATA,5
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 0
ASG:                ASP: (nil)          BKPT: 00            DESC:
MaxVelocity:
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DOL:CONSTANT        DPVT: (nil)         DRVH: 0             DRVL: 0
DSET: 0x7f8994126760                    DTYP: Soft Channel EGU:
EVNT: 0             FLNK:DB_LINK ESA:LO:2531-21:CH1:MAXV-WR:REG
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             IVOA: Continue normally
IVOV: 0             LALM: 0             LCNT: 0             LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW: 0              LSET: 0x136f8c0
LSV: NO_ALARM       MDEL: 0
MLIS: c0 69 02 20 89 7f 00 00 30 5e 02 20 89 7f 00 00 02 00 00 00
MLOK: 50 64 29 01 00 00 00 00           MLST: 0
NAME: ESA:LO:SC:2531-21:CH1:MAXV-WR:DATA                    NSEV: NO_ALARM
NSTA: NO_ALARM      OMSL: supervisory   OUT:CONSTANT        PACT: 0
PHAS: 0             PINI: NO            PPN: (nil)          PPNR: (nil)
PRIO: LOW           PROC: 0             PUTF: 0             RDES: 0x10b1220
RPRO: 0             RSET: 0x7f8994362180                    SCAN: Passive
SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SPVT: (nil)         STAT: UDF
TIME: <undefined>   TPRO: 0             TSE: 0 TSEL:CONSTANT
UDF: 0              VAL: 50
dbpr output for the other records (which don't show this problem) looks
identical for all practical purposes.
Any suggestion as to the nature of the problem and how to over come it,
would be much appreciated.
Zen
Re: EDM Zenon Szalata
EDM Zenon Szalata
Prev: epicsTimeGetEvent failed Geon-Yeong Mun
Next: Re: archiver tools macro support Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM Zenon Szalata
Next: Re: EDM Zenon Szalata
