1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsTimeGetEvent failed
To: [email protected]
Date: Fri, 10 May 2013 07:57:59 -0400
On 05/10/13 03:25, Geon-Yeong Mun wrote:
> I tried to run the mrfioc2 EPICS module for the MRF's
> VME-EVG-230&VME-EVR-230(not VME-EVR-230RF).
FYI there is a known issue with the VME-EVR-230 (not RF) firmware
identifying itself as an VME-EVRRF-230.  The 8th Front panel output
won't be configurable until this is fixed.
> When EVG generate the Event Code 125, then EVR print the error-message.
> recGblGetTimeStamp: epicsTimeGetEvent failed, TST{evr:1}Time-I.TSE = 125
The error means that timestamp 1Hz reset event #125 was received, but
the EVR did not record a valid reception timestamp.  It is expected that
this will be shown 5 times per EVR when time stamping reception begins.
Since the log you sent does not show the message "Starting
timestamping", I don't think the EVG is sending the timestamp shift events.
Of course right now I can't think of why it should work...  I'll try to
repeat this today to see if I made some mistake in the procedure.
Michael
epicsTimeGetEvent failed Geon-Yeong Mun
Prev: Actual time in XY graph Himanshu Tyagi
Next: RE: EDM Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: epicsTimeGetEvent failed Geon-Yeong Mun
Next: Re: Re: epicsTimeGetEvent failed Geon-Yeong Mun
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
