1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV value logging
To: Ralph Lange <[email protected]>
Date: Fri, 17 May 2013 05:17:05 -0700 (PDT)
Hi Ralph,
--What do you want to log?    I want to log value with Timestamp. My record scanning rate is 1 Second and i want to log at same rate. I also have some PV having I/O Intr. in that case at the time of value change.
For outputs:  Value change by operator.  and want to log the changed value with time.
-- How long do you want to log? (just during a test setup? over long periods? forever?)   It should be log value it IOC run.  we can say forever.
-- What do you want to do with the information? (use it for debugging? create plots of values over time?)   - it can be used for analysis and create plots.
-- Where do you want to log? (local on IOC console? remote on a different, maybe central, server?)   locally may be in some file etc.
Thank you very much.
To: Vikram Bhagat <[email protected]>
Sent: Friday, May 17, 2013 1:42 PM
On Fri May 17 2013 11:22:27 GMT+0200 (CEST), Vikram Bhagat <[email protected]> wrote:
      How i can enable logging of EPICS PV value?  For example logging input PV (record type ai or bi)  and even set PV (record type ao or bo) also.
I have used Asyn driver for my application.
Thanks
The answer depends on:
- What do you want to log? (value? timestamp? alarm status? For outputs: also who changed it? from where? old and new value?)
If you supply a more complete specification of your request, people will be able to point you to the best solution.
~Ralph
Re: PV value logging Ralph Lange
PV value logging Vikram Bhagat
Prev: Re: PV value logging Ralph Lange
Next: Re: Relative time in XY graph Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PV value logging Ralph Lange
