1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gauge controller with R232 serial port
To: Vahe Sahakyan <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 22 May 2013 10:28:13 +0200
Hello Vahe,
I would strongly suggest using StreamDevice [1] to interface such a device.
This approach will be much easier and faster. Writing a protocol file for your device is basically all you will have to do.
~Ralph
[1] http://epics.web.psi.ch/software/streamdevice/
On 22.05.2013 09:25, Vahe Sahakyan wrote:
Hello,
    I'm trying to create IOC for our XGS-600 vacuum gauge controller (Agilent Technologies). It is connected via RS232 serial port and I know the commands I'm going to use.
   This is my first real IOC to built. I read Norum's tutorial how to built Gpib and serial device IOCs and I have several questions:
 Can we use the http://www.aps.anl.gov/epics/modules/soft/asyn/R4-9/HowToDoSerial/tutorial.html
tutorial as base for our own IOC? If it is possible than
1) if my device is connected via serial port, should I use the same command as for gpib devices, i.e.
    /base/asyn/bin/linux-x86/makeSupport.pl -t devGpib myDevice
2) If the commands of our device have the following format:
   #0002UHFIG1,end the command ends with "\n". How can we define it in a gpibCmd structure? In a Norum's tutorial it is written as following:
    {&DSET_LO, GPIBWRITE, IB_Q_LOW, NULL, "\377\377\033", 10, 10,
       NULL, 0, 0, NULL, NULL, "\033"},
 3) In the above mentioned command to what must be changed GPIBWRITE/GPIBREAD in case of RS232 connection?
If anybody had already written an IOC for this controller I'll be very thankful to get advices.
    Thank you in advance,
                   Vahe
Re: Gauge controller with R232 serial port Eric Norum
Gauge controller with R232 serial port Vahe Sahakyan
Prev: RE: asynPrint to print asyn port name ulrik.pedersen
Next: Re: streamdevice Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Gauge controller with R232 serial port Vahe Sahakyan
Next: Re: Gauge controller with R232 serial port Eric Norum
