1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Communications with serial/LAN devices not using string oriented data
To: <[email protected]>
Date: Thu, 23 May 2013 20:52:56 -0700
I would most enthusiastically suggest using asynPortDriver C++ class (by Mark Rivers) to be used as a base class for your device driver. I am sure there are many examples around.
Zen
On 05/23/13 16:32, Rod Nussbaumer wrote:
Hi All.
We have been asked to provide support for a device that communicates
serially using packets of binary data. Ordinarily for such tasks I would
use streamDevice, but the command protocol for this device (a CPI RF
amplifier) is all binary, not strings, and even includes the requirement
to byte stuff when framing characters are in the packet payload, as well
as compute checksums on the packets.
Any recommendations about how to approach this kind of problem? There
are a LOT of different commands required to operate this device.
Thanks
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Communications with serial/LAN devices not using string oriented data Rod Nussbaumer
Prev: RE: More on Modbus Mark Rivers
Next: Re: More on Modbus Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Communications with serial/LAN devices not using string oriented data Eric Norum
Next: Re: Communications with serial/LAN devices not using string oriented data Andrew Johnson
