1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbFreeLink called but link type unknown
Cc: [email protected]
Date: Fri, 24 May 2013 11:20:38 -0400
Certainly. Thanks for the help!
Running 3.14.11. I can narrow it down to this simple-ish test case.
-->  load commands (loaded by dbLoadTemplate)<--
file "insertablesV/db/inchannels.db"
pattern {cardname, devicetype, deviceaddr, description}
{"E201B06C0943ADDR3", "VMIC0943", "#C3 S2 @MES", "limit switch"}
{"E201B06C0943ADDR4", "VMIC0943", "#C4 S2 @MES", "limit switch"}
-->  db file<--
record(ai, "$(cardname):ai") {
  field(DESC, "$(description)")
  field(DTYP, "$(devicetype)")
  field(FLNK, "$(cardname):mux2")
  field(INP, "$(deviceaddr)")
  field(SCAN, ".2 second")
  field(PINI, "YES")
record(calc, "$(cardname):mux1") {
  field(FLNK, "$(cardname):low")
  field(CALC, "A AND 65535")
  field(INPA, "$(cardname):ai")
record(calc, "$(cardname):mux2") {
  field(FLNK, "$(cardname):mux1")
  field(CALC, "A>>  16")
record(mbbiDirect, "$(cardname):high") {
  field(INP, "$(cardname):mux2")
record(mbbiDirect, "$(cardname):low") {
  field(INP, "$(cardname):mux1")
  field(FLNK, "$(cardname):high")
Feel free to offer any design advice as well. :)
- Mike
On 05/24/2013 10:51 AM, Andrew Johnson wrote:
Hi Michael,
On 2013-05-24 Michael Johnson wrote:
I'm seeing this error (warning?) when I load a new database.
I've looked through EPICS source for the message, but I can't make out what
it's trying to tell me.
We need a bit more information: What version of Base are you using, does this
only happen for one record type, device type or record instance (and if so
please include that part of the .db file).
- Andrew
Re: dbFreeLink called but link type unknown Andrew Johnson
dbFreeLink called but link type unknown Michael Johnson
Prev: Re: dbFreeLink called but link type unknown Andrew Johnson
Next: Re: Communications with serial/LAN devices not using string oriented data Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: dbFreeLink called but link type unknown Andrew Johnson
