1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor record .RDBD field
Date: Tue, 28 May 2013 08:57:25 +1000
Hi all,
I've stumbled into this issue a couple of times now so I thought it was worth a message to tech-talk.
The .RDBD field of the motor record limits the smallest allowed move - quite often we want to set this very low so that we can do small step moves.  However, in a few cases we also want to use the motor record's retry mechanism by setting .UEIP to 'Yes' and feeding the encoder into .REP (I'm using the tpmac driver which allows you to do this when the encoder is on a different channel).  Because .RDBD is now used as the retry deadband, we need to make it larger since it is not capable of attaining such an accurate position.
It would be better if we could somehow decouple the use of .RDBD in the retry sense from the smallest allowed move.  Have other people run into this and found a solution?  In the meantime I need to keep switching between modes (toggling .UEIP and changing .RDBD appropriately) to allow me to do scans in very small steps followed by a wind-back which uses retries to ensure I'm not losing steps.  It's a bit messy and not ideal.
Of course if we had perfect mechanics we wouldn't need to be doing retries at all, but c'est la vie!
Emma
P.S. I hope I haven't missed a thread on this already, the APS website seems to be down at the moment so I can't check
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
Re: Motor record .RDBD field Tim Mooney
Re: Motor record .RDBD field Ron Sluiter
Prev: RE: More on Modbus Mark Rivers
Next: Re: Motor record .RDBD field Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbFreeLink called but link type unknown Michael Johnson
