1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: National Instruments PCI DAQmx
To: [email protected]
Cc: Rafael Vescovi <[email protected]>
Date: Tue, 28 May 2013 12:05:54 -0500
Hi Andrew & Rafael,
On 2013-05-28 Gomella, Andrew (NIH/NHLBI) [F] wrote:
> I also don't believe Henirch du Toit works on EPICS any more.
Correct, he left iThemba LABS in 2008:
  http://www.aps.anl.gov/epics/tech-talk/2008/msg00434.php
> I think fixing up the COMEDI driver he wrote is probably the way to move
>  forward (especially given its long list of supported hardware). I think if
>  it is brought up to date with the changes that have been made to asyn it
>  should work fine. http://www.comedi.org/
> http://sourceforge.net/projects/epicscomedi/
It would probably be worth trying to get control of that epicscomedi project
at SourceForge if someone has the time to do that.  I would suggest merging it
with the epics project http://sourceforge.net/apps/trac/epics/wiki but that's
up to whoever does the work (thank-you if you do).
I have been reading that some Comedi drivers are being reworked and added to
the Linux Kernel, although I have no idea whether this would affect the EPICS
drivers at all.  Of course it'll be quite some time (years) before those make
it to the Red Hat releases (and hence to Scientific Linux) that many EPICS
labs actually use.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
National Instruments PCI DAQmx Rafael Vescovi
RE: National Instruments PCI DAQmx Gomella, Andrew (NIH/NHLBI) [F]
Prev: Re: EPICS on an embedded device Florian Feldbauer
Next: Re: EPICS on an embedded device Diego Omitto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: National Instruments PCI DAQmx Gomella, Andrew (NIH/NHLBI) [F]
Next: EDM Zenon Szalata
