Michael,
We were thinking about the same approach, using dfanout to get the SCAN
value fanned out to the the destination records. Will give a try with
the dfanout records.
Ralph, we're going to give it a try, haven't worked with the seq rcord
though until now.
Thanks!
Best regards,
Hinko
On 06/07/2013 10:36 AM, Ralph Lange wrote:
On 07.06.2013 10:01, [email protected] wrote:
We would like to set a SCAN field on several lower level BO records, at
the same time, and the value of these SCAN fields should reflect the
value of the single higher level record SCAN field.
For the control of these lower level SCAN fields another, higher level
record, would be used. If a user wishes to set individual lower level
record SCAN fields, she is allowed. OTOH, when changing the SCAN of the
higher level record, ALL lower lever BO records would get their SCAN
field set too.
Is it possible to get this done without using a sequencer?
I suggest an alternative architecture:
1. Have a single controlling record with controllable SCAN.
2. Set all your low level records to SCAN='Passive'
3. Use a chain of fanout records to force processing of the low level records
4. Use the FLNK of the controlling record to trigger the fanout.
Note, though, that this solution does not fulfill the requirement "OTOH,
when changing the SCAN of the higher level record, ALL lower lever BO
records would get their SCAN field set too." Once a BO has been set to a
different SCAN, it has to be changed back manually to "Passive" to get
scanned by the higher level SCAN period.
If you want the forced reset behaviour, you will have to replace the
fanouts by seq records that forward the high level SCAN to each of the
BO SCAN fields. Point some input link of the first seq to the higher
level SCAN field and make it CP to start the SCAN fanout chain whenever
the high level SCAN changes.
~Ralph
- Re: Changing SCAN field in many records Ralph Lange
- Changing SCAN field in many records Hinko Kočevar
- RE: Changing SCAN field in many records michael.abbott
Re: Changing SCAN field in many records Hinko Kočevar
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
