1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: analog output record - constant DOL
To: tech_talk <[email protected]>
Date: Fri, 14 Jun 2013 07:24:16 -0700
I ran into some  behaviour of the analog output record which surprised me:
I have several ao records, all DTYP="Soft Channel", which - when processed - are meant to send different constant values each to a target record. I am setting DOL to the desired constant value and OMSL=closed_loop and everything seems to work as desired. When I do a caput to one of these ao records, however, the record outputs from this moment the value received from the caput and ignores the DOL value.
This seems counter-intuitive to me. I had expected that in closed_loop mode, the VAL field would be *always* obtained from the DOL link.
The record processing routine shows that this is the programmed behaviour (during record init the VAL field has been loaded from the constant link):
    /* fetch value and convert*/
    if (prec->pact == FALSE) {
                if ((prec->dol.type != CONSTANT)
                && (prec->omsl == menuOmslclosed_loop)) {
                    status = fetch_value(prec, &value);
                else {
                    value = prec->val;
        if(!status) convert(prec, value);
        prec->udf = isnan(prec->val);
The recordreference manual (3.14) does not say anything about the behaviour of a constant link:
"... If closed_loop is specified, the VAL field's value is obtained from the address specified in the desired output location field (DOL), which can be either a database link or a channel access link. ..."
Does anyone remember what the rationale is for treating a constant link differently from a db or ca link?
- rolf -
| Rolf Keitel, Ph.D.                Tel: (604) 222-7453 |
| TRIUMF                                                |
| Vancouver, B.C., Canada                               |
Re: analog output record - constant DOL Andrew Johnson
Prev: GUI Control System Options Jeremy Iken
Next: VAL field of PV in ASYN driver Vikram Bhagat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: GUI Control System Options Chen, Xihui
Next: Re: analog output record - constant DOL Andrew Johnson
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
