1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AutoSAVE file cannot use substitution macros
To: Amien TLABS <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Jun 2013 13:40:05 +0000
You did not show us the autoSave .req file you are using.  .req files can take macros.  For example:
corvette:areaDetector/ADApp/Db>more ADBase_settings.req
$(P)$(R)DataType
$(P)$(R)ColorMode
$(P)$(R)BinX
$(P)$(R)BinY
$(P)$(R)MinX
That generic .req file is invoked by the IOC-specific .req file:
corvette:areaDetector/iocBoot/iocSimDetector>more auto_settings.req
file "simDetector_settings.req",    P=$(P),  R=cam1:
file "simDetector_settings.req",    P=$(P),  R=cam2:
file "ADBase_settings.req",         P=$(P),  R=cam1:
which is in turn invoked from the startup script:
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=$(PREFIX)")
From: [email protected] [[email protected]] on behalf of Amien TLABS [[email protected]]
Sent: Thursday, June 20, 2013 8:23 AM
To: [email protected]
Subject: AutoSAVE file cannot use substitution macros
Hi
I'm using a 'waveform' record in my IOC, which I use to map my cable wiring to my channels at the start of the IOC.
To populate the array, I then use a 'sav' (AutoSave) file that has the array values in it ( dev1:channelmap.VAL @array@ {"2" "12" "7"}) ) etc. This array is normally 48 elements.
Now the users of the IOC can change this array to suit their mappings.
My problem is that I would like to have a substitution macro in the 'dev1' part. However, one cannot use a substitution macro in a 'sav' file.
I have a waveform record in my template file. Here's my st.cmd and template files:
################## START IOC SCRIPT #####################################
dbLoadDatabase("iocBeagle48.dbd")
iocBeagle48_registerRecordDeviceDriver(pdbbase)
int32DriverInit("int32",-32768,32767)
##### We load the HARPS template  ##########################################
dbLoadTemplate("iocPV.substitutions")
##### Load Save files  #####################################################
set_savefile_path("save")
set_pass0_restoreFile("channelmap_MB.sav")
set_pass1_restoreFile("channelmap_MB.sav")
#### INIT IOC here  #######################################################
iocInit()
<<< Here's my iocPV.db >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
record(waveform,   "$(dev):channelmap") {
       field(DTYP, "asynInt32ArrayOut")
       field(INP,  "@asyn(int32 0 100)")
       field(NELM, "48")
       field(FTVL, "LONG")
       field(PINI, "YES")
<<< here's my substitution file >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
file iocPV.db
 pattern { dev        mux }
         {"harp100"   "1" }
<<<<<<< and my SAV file  >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
# save/restore V5.5    Automatically generated - DO NOT MODIFY - 130215-051243
harp100:channelmap.VAL @array@ { "32" "0" "1" "2" "3" "4" "5" "6" "7" "24" "25" "26" "27" "28" "29" "30" "31" "47" "17" "18" "19" "20" "21" "22" "23" "8" "16" "10" "11" "12" "13" "14" "15" "9" "33" "34" "35" "36" "37" "38" "39" "40" "41" "42" "43" "44" "45" "46" }
<END>
As you can see, i want to have a substitution macro for my sav file (harp100 should be substituted by pattern dev)
Or maybe there is a better way to populate my waveform.
Thanks
Amien
TLABS
Cape Town.
Re: AutoSAVE file cannot use substitution macros Amien TLABS
Prev: AutoSAVE file cannot use substitution macros Amien TLABS
Next: Re: AutoSAVE file cannot use substitution macros Amien TLABS
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
