1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: help setting up XY table control with EPICS StreamerClass
To: [email protected]
Date: Thu, 20 Jun 2013 18:05:39 +0200
Hi
I am trying to set up EPICS control for a XY-scanning table.
Control of the motor controller for the two stepper motors via RS232 is rather simple, and already implemented via StreamerClass:
The controller understands 4 simple commands:
u100/r
d100/r
l100/r
r100/r    to move the motors up/down/left/right by 100 steps.
In return, AFTER FINISHING the move (which can take up to 10sec), the controller returns a "OK/r/n"
So far i was using a protokoll like this:
move {
    out "\$1%d\r";
    in "OK\r\n";
and 4 EPICS records for moving like this:
record(longout, "XY:movel")
    field(DESC, "Move XY-Table left")
    field(DTYP, "stream")
    field(OUT,  "@devXYtableSupport.proto move(l) $(PORT) $(A)")
    field(FLNK, "XY:posX.PROC")
However, due to the long move-times, this is not ideal. As i understand from the documentation, one should rather implement an asynchronous control.
Best would be, to have a separate boolan record "motorsmoving" which is set to "TRUE" every time i send a move command to the controller, and which is set back to "FALSE" once the controller sends back the "OK".
Any advice how to proceed ???
I am fighting for days now...
Thanks for any help !
Christian
Dr. Christian Pauly
Bergische Universität Wuppertal
Fachbereich C - Physik
Gaußstraße 20, D-42119 Wuppertal
Tel: +49 (0)202 439-2632,
Fax: +49 (0)202 439-2662
Re: help setting up XY table control with EPICS StreamerClass Eric Norum
Prev: Re: starting Archive Engines Kasemir, Kay
Next: Re: help setting up XY table control with EPICS StreamerClass Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: starting Archive Engines James F Ross
