1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New EPICS support module "feller", release 0.1
Cc: [email protected]
Date: Thu, 20 Jun 2013 16:57:07 -0500
On 6/20/13 4:19 PM, Andrew Johnson wrote:
> Hi Lewis,
> On 2013-06-20 J. Lewis Muir wrote:
>> Why would I want to use this wrapper instead of just using the EPICS
>> errlog facility directly?
> See these tech-talk messages for context:
> http://www.aps.anl.gov/epics/tech-talk/2013/msg01107.php
> http://www.aps.anl.gov/epics/tech-talk/2013/msg01115.php
> http://www.aps.anl.gov/epics/tech-talk/2013/msg01126.php
> http://www.aps.anl.gov/epics/tech-talk/2013/msg01256.php
Hi, Andrew.
Thanks for the context.
>> I didn't think the EPICS errlog facility provided a way to log to a
>> file;
> It does if you connect it to an iocLogServer, see section 10.7 in the
> AppDevGuide.
Right, I understand that.  But I'm (not very clearly) asking about the
case of writing to a file from an IOC using errlog and not depending on
another host.  Are you saying one can run iocLogServer on the same host
as the iocLogClient?  Will this work on vxWorks too?  I hadn't thought
of doing that.  This would be a new way (to me anyway) of writing to a
file from one IOC using errlog without depending on another host.
>> how does Feller log to a file using the EPICS errlog facility?
> I assume it registers an errlogListener routine on the IOC by calling
> errlogAddListener() (section 10.3 of the AppDevGuide) and writes the messages
> it gets to the file.
OK, so here's where I could benefit from using feller: If my goal was to
write to a file using errlog from an IOC and *not* run iocLogServer at
all (i.e. not on the same host nor any other host), I could use feller
to do this.  I think I've got it.
Lewis
RE: New EPICS support module "feller", release 0.1 Mark Rivers
Re: New EPICS support module "feller", release 0.1 Andrew Johnson
seqLog obsolete / errlog filtering based on source Emmanuel Mayssat
New EPICS support module "feller", release 0.1 Benjamin Franksen
Re: New EPICS support module "feller", release 0.1 J. Lewis Muir
Prev: Re: New EPICS support module "feller", release 0.1 Andrew Johnson
Next: RE: New EPICS support module "feller", release 0.1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
