1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem in errlogRemoveListener
To: <[email protected]>
Date: Fri, 21 Jun 2013 11:18:07 +0200
The errlog facility provides errlogAddListener, and errlogRemoveListener.
Unfortunately, the latter is broken, as there is no way to specify the
listener's private data. So if I have two listeners which differ only in their
private data (such as when using two instances of feller), then I can only
remove them all at once, not each one separately.
The attached patch file rectifies that by adding an errlogRemoveSingleListener
function to the API that allows to remove single instances.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachm€nts
Fri Jun 21 11:15:25 CEST 2013  [email protected]
  * FIX: libCom/error: added errlogRemoveSingleListener
diff -rN -u old-3-14-12-2-1/src/libCom/error/errlog.c new-3-14-12-2-1/src/libCom/error/errlog.c
--- old-3-14-12-2-1/src/libCom/error/errlog.c	2013-06-21 11:17:28.886150560 +0200
+++ new-3-14-12-2-1/src/libCom/error/errlog.c	2013-06-21 11:17:30.449710101 +0200
@@ -324,6 +324,28 @@
+epicsShareFunc void epicsShareAPI errlogRemoveSingleListener(
+    errlogListener listener, void *pPrivate)
+    listenerNode *plistenerNode;
+    errlogInit(0);
+    if (!pvtData.atExit) epicsMutexMustLock(pvtData.listenerLock);
+    plistenerNode = (listenerNode *)ellFirst(&pvtData.listenerList);
+    while (plistenerNode) {
+        if (plistenerNode->listener==listener && plistenerNode->pPrivate==pPrivate) {
+            ellDelete(&pvtData.listenerList, &plistenerNode->node);
+            free((void *)plistenerNode);
+            break;
+        plistenerNode = (listenerNode *)ellNext(&plistenerNode->node);
+    if (!pvtData.atExit) epicsMutexUnlock(pvtData.listenerLock);
+    if (!plistenerNode) {
+        fprintf(stderr, "errlogRemoveListener did not find listener\n");
 epicsShareFunc int epicsShareAPI eltc(int yesno)
     errlogInit(0);
diff -rN -u old-3-14-12-2-1/src/libCom/error/errlog.h new-3-14-12-2-1/src/libCom/error/errlog.h
--- old-3-14-12-2-1/src/libCom/error/errlog.h	2013-06-21 11:17:28.882151686 +0200
+++ new-3-14-12-2-1/src/libCom/error/errlog.h	2013-06-21 11:17:30.449710101 +0200
@@ -58,6 +58,8 @@
     errlogListener listener, void *pPrivate);
 epicsShareFunc void epicsShareAPI errlogRemoveListener(
     errlogListener listener);
+    errlogListener listener, void *pPrivate);
 epicsShareFunc int epicsShareAPI eltc(int yesno);
 epicsShareFunc int epicsShareAPI errlogInit(int bufsize);
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Problem in errlogRemoveListener Benjamin Franksen
Prev: Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
Next: Re: Problem in errlogRemoveListener Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Scientific programmer II position available at the Joint Astronomy Centre Maren Purves
