1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: help setting up XY table control with EPICS StreamerClass
To: EPICS Tech Talk <[email protected]>
Date: Fri, 21 Jun 2013 11:39:02 +0200
Hi Christian,
On Fri Jun 21 2013 11:07:38 GMT+0200 (CEST), Christian Pauly
<[email protected]> wrote:
> No, only one motor can move at a time.
> But i thought it is "bad style" to do this synchronous with such large
> delays ? ( I had to define huge timeouts in the protocol to get it
> work...)
This rule of not doing synchronous device support for devices with long
delays applies to writing device support.
If you are using StreamDevice (which I assume), your device support is
not synchronous - StreamDevice and ASYN support below are working
asynchronously and take care of the gory details for you.
The port that you are communicating with will be locked while a protocol
(like your move command) is running. But that is fine if the device can
only use one motor at a time.
Cheers,
~Ralph
Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
Prev: Re: Problem in errlogRemoveListener Benjamin Franksen
Next: Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
