1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Record Processing
Date: Thu, 27 Jun 2013 09:11:13 -0700
Hi Mark,
Yes it does. I believe it does get called for this record. I put a print statement in the readInt32 routine and was surprised that it is getting called for most of the implemented records, both longin and longout. I have implemented action in the readInt32 routine for some of the longin records. For any other record I call status=asynPortDriver::readInt32 and status is returned.
Zen
On 06/26/13 22:59, Mark Rivers wrote:
It does not make sense that it is writing 0.
Does your driver implement readInt32 and does it get called during iocInit for that record? If so what does it return as the status function return value?
Sent: Wednesday, June 26, 2013 12:01 AM
To: Mark Rivers; [email protected]
Subject: Record Processing
Hi Mark,
I have a simple longout record
record( longout, "$(P):LO:DEBUG-$(M):MFUNC"){
    field( DESC, "Modbus Func:")
    field( DTYP, "asynInt32")
    field( OUT,  "@asyn(DEBUG,0,1)LO_MFUNC")
    field( VAL,  "3")
    field( PINI, "YES")
It is a part of an IOC which uses asynPortDriver class driver.  I put a
print statement in writeInt32 function and at IOC initialization time it
prints that the value to write is 0.
Then at the end of st.cmd script I have put a
dbpf <record name>.PROC 1
for this record and this time the value to write is 3.  Why is the
record writing 0 at IOC initialize time?
I am not sure if this is a basic EPICS or asyn issue, so I thought I ask
you.
Zen
RE: Record Processing Mark Rivers
Record Processing Zenon Szalata
Prev: Re: caget apparent timeout D Peter Siddons
Next: Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Record Processing Mark Rivers
Next: RE: Record Processing Mark Rivers
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
