On 27.06.2013 16:33, Brian McAllister wrote:
On 6/27/2013 at 7:18:58 -0000, Mark Rivers wrote:
> My next guess is that there may be a firewall running on your
> system. Is iptables running?
You are correct. Inbound connections on eth1 were blocked and I had eth0
restricted to SSH/tcp while I was setting up the machine. Normally I allow
all traffic from the local subnet.
Opening eth0 (or eth1) fixes the problem. If I open both, then I need to
set EPICS_CA_AUTO_ADDR_LIST=NO and use EPICS_CA_ADDR_LIST.
I still don't understand why it didn't work from the local host. iptables
accepts all traffic from the loopback. Why doesn't that work for CA ?
- brian
BTW: We use iptables to block the second network port for CA instead of
tweaking EPICS_CA_ADDR_LIST.
Dirk
- Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
RE: Please help us with some error when running a softGlue application! Mark Rivers
Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
<2013>
2025
Re: caget can't connect to soft ioc on host with multiple NICs Andrew Johnson
ca_get and ca_put triggered by monitors? Dirk Zimoch
<2013>
2025
