Hi Dominique,
On 2013-07-05 Dominique Touchard wrote:
> It seems that the number of macros for template substitutions during IOC
> startup is limited to 100. Over, a segmentation fault stop the IOCs.
> Is this number correct? Is there any reason?
I was surprised but you're right, src/dbtools/dbLoadTemplate.y defines
VAR_MAX_VARS as 100 which sets a limit to the number of variables that
dbLoadTemplate() can handle. It also defines VAR_MAX_VAR_STRING as 5000
setting the maximum size of the "variable=value,..." string which it
constructs to pass to dbLoadRecords(). In neither case though does it check
when the storage limit set by those macros gets exceeded, thus causing a
crash. This is obviously unacceptable and needs to be fixed in Base.
To get around this limit for a particular application you could do the
template expansion on the host at build time using the msi (Macro
Substitution and Include) program which is distributed as an EPICS extension.
You can also increase the above values in your source code and rebuild base,
which might be a simpler fix in some circumstances.
I have filed a bug-report for this issue. If someone feels inclined to look
at rewriting the dbLoadTemplate() code to remove these limitations please let
me know.
https://bugs.launchpad.net/epics-base/+bug/1198234
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Macros limited (edition ;-) Touchard Dominique
Re: Reading binary file from sscan saveData Hovanes Egiyan
Re: Development with EPICS and CSS marcus . michalsky
<2013>
2025
Development with EPICS and CSS Ganesh Jangir
<2013>
2025
