1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Canberra AIM MCA 556B
To: [email protected]
Date: Thu, 18 Jul 2013 17:21:02 +0200
Hi Mark,
we are using an AIM 556B successfully compiled against mca release 7-1 and epics release 3.14.12.2, running on an suse linux softIOC.
It comes with an build-in ethernet interface, no need for an AUI!
MAC address of our model is 1125
HTH
Peter Mueller in
Physikalisch-Technische Bundesanstalt
Division 7.13 at Bessy II
postal address:
Physikalisch-Technische Bundesanstalt (PTB)
Abbestrasse 2-12
10587 Berlin
Germany
phone:  +49 (0)30 6392-5092
fax:                  -5082
e-mail: [email protected]
Am 17.07.2013 17:28, schrieb Mark Rivers:
> Folks,
> A group at NSLS has a new Canberra AIM 556B, which is a newer model than the 556 and 556A.  They want to use it with my EPICS support (synApps mca module). I don't have a 556B for testing, so I'm wondering if anyone has successfully used it?
> Thanks,
> Mark
> From: Yin, Zhijian [[email protected]]
> Sent: Wednesday, July 17, 2013 9:54 AM
> To: Mark Rivers
> Cc: D. Peter Siddons
> Subject: Canberra AIM MCA 556B
> Hi, Mark,
> We've been using your epics mca support for Canberra AIM 556 at two beamlines at NSLS. We need one more mca, and last year we purchased an AIM 556, but it turned out to be a newer model, 556B, which comes with with RJ45 connector, rather than that of 556A, a 10based-2.
> Tried with EPICS mca module R7-1 and 7-2, does not work. The unit has mac address marked "111C", so I replaced the AIMConfig line with 0x111C in st.cmd - the older unit has three digit, but this is not a problem - nmc_comm
> _sub2.c takes care of that.
> nmcDemo eth0 0x111c stops at nmc_initialize()
> # ./nmcDemo eth0 0x111c
> Using AIM-Module 111c
> Calling nmc_initialize ...
> (nmc_initialize): waiting returned 1
> Calling nmc_build_enet_addr ...
> Any suggestions? maybe it's a new firmware - most likely I guess? Does anyone at APS has a 556B working? Would it be possible for us to ship you the unit so you could take a closer look?
> I am using 3.2 kernel (debian 7, 32bit), so I compiled with LLC socket.  Also tried libnet libpcap (not recommended), still no go, the same message.
> Thanks,
> ZY
RE: Canberra AIM MCA 556B Mark Rivers
Prev: motor record & PC6K: program upload fails Konrad, Martin
Next: RE: Canberra AIM MCA 556B Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Canberra AIM MCA 556B Mark Rivers
