1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Odd problems with RHEL6 diskless machines
To: <[email protected]>
Cc: [email protected]
Date: Wed, 24 Jul 2013 15:57:02 +0000
I wrote a tiny C program that prints the time taken to do a usleep in a loop, and that also displays the behaviour, so I guess this has nothing to do with EPICS! I'll get onto red hat and see if they have any ideas...
Tom Cobb
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 24 July 2013 16:33
> To: Cobb, Tom (DLSLtd,RAL,DIA)
> Subject: Re: Odd problems with RHEL6 diskless machines
> Hi Tom,
> On 07/24/2013 09:45 AM, [email protected] wrote:
> > When running an IOC with just devIocStats in it, all of the scan
> > tasks seem to pause for up to 300 seconds (about half of the pauses
> > are between 299 and 301 seconds), then resume. During this time an
> > existing ssh connection to the server will continue to work, but
> > channel access monitors may time out. R3.14.8.2, R3.14.11 and
> > R3.14.12.3 IOCs are all affected. dmesg and /var/log/messages show
> > nothing suspicious, and cat /proc/sys/kernel/random/entropy_avail
> > returns 3968.
> Interesting problem...
> Does this have anything to do with devIocStats and the fact that you're
> presumably running the IOC as a real-time process?  I don't know the
> internals of that module running on Linux, but the old VxStats module
> on
> vxWorks has a lowest-priority idle thread that every so often busy-
> waits
> for a specific period of time to measure how much work the CPU does in
> the higher priority threads.  I could see a problem if devIocStats is
> trying to use the same technique on Linux because IIRC all real-time
> (SCHED_FIFO) threads still have a higher priority than regular threads,
> and this could cause the effect you're seeing.  Why it only seems to
> affect diskless systems is still a bit of a question, but I could think
> up some reasons for that.
> Take a look at the internals of devIocStats, and if it has such an idle
> task try disabling it (it should be asking the OS instead of trying to
> measure it anyway).  Alternatively, see if not running the IOC as a
> real-time process stops the problem.
> HTH,
> - Andrew
> Advertising may be described as the science of arresting the human
> intelligence long enough to get money from it. -- Stephen Leacock
Odd problems with RHEL6 diskless machines tom.cobb
Re: Odd problems with RHEL6 diskless machines Andrew Johnson
Prev: Re: Odd problems with RHEL6 diskless machines Andrew Johnson
Next: Re: Odd problems with RHEL6 diskless machines Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
