1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record: continuously update limit switches
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 26 Jul 2013 20:07:25 +0000
Hi!
Thanks for you reply, Mark.
> HLS, RHLS, LLS and RLLS only update when you try to move the motor in
> the direction of the offending switch.
> However, the MSTA field will update if you write 1 to the STUP
> field.
Unfortunately this seems not to be the case with the PC6K device
support. MSTA seems not to be updated while the motor is stopped. Can
this be considered a bug?
> Is your goal to make the user aware of the limit status by changing
> something in the GUI?
Yes, exactly. Maybe also for a state-machine that implements some sort
of a calibration procedure.
> It would be nice if HLS, RHLS, LLS and RLLS reflected the actual
> limit status.  In fact the motor record documentation is wrong.  For
> HLS and RHLS it says:
> " If either of these fields is nonzero, then the motor is at the
> positive-limit switch, where the positive sense is that of the
> user-coordinate system for HLS, and that of the raw (step-number)
> coordinate system for RHLS."
> That is not true, it does not reflect the state of the switch.  It
> only reflects the error status if the switch is hit and the user
> tries to move in the direction of that switch.
@Ron/Tim/Joe: Can you fix the documentation with the next release,
please? And while we're at it: The Documentation website says "Last
modified: June 25, 2003" which is most likely wrong as well.
Thank you very much,
Martin
RE: motor record: continuously update limit switches Mark Rivers
motor record: continuously update limit switches Konrad, Martin
Prev: CA question with two identical servers Goff, Steven J
Next: RE: motor record: continuously update limit switches Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: motor record: continuously update limit switches Mark Rivers
