1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Thorlabs USB Hardare with EPICS
Date: Fri, 2 Aug 2013 12:42:02 +0000
Dear all,
I have some problems to establish a longer lasting connection with a Thorlabs PM100USB Powermeter.
It is listed in /dev as usbtmc0 and I can communicate with it through echo –e. But this is only possible for one time. A second time echo –e won’t work. I have to disconnect and reconnect the USB-cable. Then again it will work one time.
Could you help me with this problem?
Note: This device has two chips, the first one is a XILINX XCR3064XL (AD Converter) and the second a NXP LPC2387FBD100.
Best regards,
Hardy Drube
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Thorlabs USB Hardare with EPICS Eric Norum
Prev: RE: Electronic Logbooks Emmanuel Mayssat
Next: Re: Thorlabs USB Hardare with EPICS Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Ipac driver 2.12 release candidate Andrew Johnson
